Old 10-19-2017, 03:24 PM   #1
Artic pack
Do I have to keep water in all 3 tanks if I have the heaters on?
welder is offline   Reply With Quote
Old 10-19-2017, 04:33 PM   #2
Just as confused as you
Scrapper's Avatar
Yes, otherwise the heater coils will get hot and burn out or weaken the bottoms of your tanks. I could be wrong, but I don't think there is a thermostat on the heaters.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Scrapper is online now   Reply With Quote
Old 10-19-2017, 04:57 PM   #3
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
First of all, "Arctic Pack" is only a marketing ploy. If you have heat pads, they are usually 12 volt stick on pads with internal wiring like a heated blanket. They transfer a small amount of warmth to the bottom of the tanks where the tank contents absorb this warmth. They will lose their effectiveness when the tanks are empty but will not harm anything if left on. We keep our fresh water tank filled, black tank closed and the gray tanks open with the tank heaters on, no problem.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 10-19-2017, 05:07 PM   #4
44 -64 deg F on and off with "FLUID in Tanks" never have heat on without Fluid! Now the Valve and pipe heaters have no Themostat they are just On/Off! So this is a confusing situation when the system Only has 1 switch for all Heaters in the system! Just the Messenger! Youroo!! This came from the "Ultraheat Web Page"!
