Old 11-04-2015, 08:51 AM   #51
Commercial Member
Originally Posted by WVFR3 View Post
Hello Eric,
My question is. I'm trying to install a vortex fan on the bathroom of my 2015 30DS. I have no power to the wires that are at the vents. Have checked the 12v fuses, main disconnect switch is on. The lights in the bathroom, living room and bedroom all work. Where does this prewired wire get its power? I could splice into the lights, but would rather do it right the first time. Thanks for any info.
Check the fuse box in the distribution panel in the bedroom, it is located next to the breaker box. The prewire should be pulling power from here.
FR3Eric is offline   Reply With Quote
Old 11-04-2015, 10:57 AM   #52
HAPPY WHEN RV'ING
drivmsafe's Avatar
Originally Posted by drivmsafe View Post
Have a look in your house battery compartment. You should see a small black circuit breaker just above the batteries. If you see an arm sticking out at a 45 degree angle, push it back down. This breaker is for that overhead bunk.
Boy did I have my head up my butt or what?! I can't believe I told you about the circuit breaker for the levelers instead of the fuse next to the batteries for the bunk. Must be lack of.... (I'm not going there)
Very sorry for the misinformation.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 11-04-2015, 02:57 PM   #53
Commercial Member
Originally Posted by Lexi2007 View Post
It's mighty nice to see an FR 3 professional on board.
We have a 2015 FR3 DS. Is it possible it was built without either a black tank wash out valve or a check valve between the fresh water and city water tanks? I'm sure I'll think of more questions over time.
In 2015 we did add a black tank flush system. The easiest way to tell if your coach has the black tank flush installed from the factory is by checking how many connections you have in your plumbing bay. In this bay you should find a Fresh tank fill, a city water fill, and black tank flush. if you only have two of these three then you do not have the factory installed black tank flush.
Old 11-05-2015, 12:25 AM   #54
Greg-Gabe's Avatar
Rear camera question. We have a 2016 FR3 30DS with the Pioneer AV system. Is there a way to set rear back up camera to stay on? I would love to keep an "eye" on the toad!
Greg-Gabe is offline   Reply With Quote
Old 11-05-2015, 09:06 AM   #55
Antone's Avatar
Originally Posted by patanke View Post
Hi Eric, is there a master list of fuse locations, size, and what they protect? Or a detailed electrical schematic showing them?
On my 2016 30ds there seem to be fuses located all over, some are located in panels some installed inline.
I try to look for the easy stuff, and fix what I can before bringing it for warranty work, but the lack of information makes trouble shooting difficult.
I have some older schematics from the forum, but if you have any additional drawings electrical and/or any other systems, or additional engineering documents that could be shared it would help all of us, and help reduce FR's warranty costs.
Scott
F-53 Manual has all chassis fuses noted. You can find it online.
Antone
2015 Forest River FR3 30DS - No Ragrets
Toad - 2011 Jeep Wrangler
Antone is offline   Reply With Quote
Old 11-05-2015, 09:42 AM   #56
Originally Posted by Antone View Post
F-53 Manual has all chassis fuses noted. You can find it online.r
Yes, that's true. But I think he was asking about the "hidden" in-line fuses that aren't in a fuse block, such as the ones for the slide-outs, the leveling jacks, the overhead bunk, etc. It would be nice to have a list and location map for those.
2016 FR3 30DS
vacationlovers is offline   Reply With Quote
Old 11-05-2015, 10:46 AM   #57
Antone's Avatar
Ah, got it. I haven't seen anything for that and it would be nice.
Antone
Old 11-05-2015, 06:49 PM   #58
Lexi2007's Avatar
On our 2015, there is a power on/off button and I power it on when pulling out. Granted, it switches off when the ignition goes off but I just power it back on. Hopefully things haven't changed that much between the 2015 and 2015 models.
Ken & Val [Lexi's mom] Moczygemba & Tori the dog
Adkins, TX
2017 Coachmen Concord 300 DS [Lexi III]
Lexi2007 is offline   Reply With Quote
Old 11-05-2015, 07:25 PM   #59
StephanFR3's Avatar
My 2014 will stay on by settings.
StephanFR3 is offline   Reply With Quote
Old 11-05-2015, 11:06 PM   #60
Greg-Gabe's Avatar
I got it to come but as soon as I shifted it into Drive it goes blank with a warning not to view while driving...
