Old 11-06-2015, 10:35 AM   #61
Post Setting Camera View mode
Originally Posted by Greg-Gabe View Post
Rear camera question. We have a 2016 FR3 30DS with the Pioneer AV system. Is there a way to set rear back up camera to stay on?
Yes, there is. If you look at page 41 in the Pioneer AVH-X2700 Owner's Manual, there's a section titled "Setting the camera for Camera View mode". Basically, you need to bring up the System Settings screen, then touch Camera Settings, and then Camera View.
The rear camera will be displayed on the screen while you're driving. If you want to change radio stations or something, just touch the screen, and the camera view will go away for awhile, then return when you stop touching the screen.
2016 FR3 30DS
vacationlovers is online now   Reply With Quote
Old 11-06-2015, 07:15 PM   #62
b1barnes's Avatar
Originally Posted by FR3Eric View Post
Below you will find the part numbers for the sealed headlights with the LED rings. We used to purchase these through ABC Marketing out of Elkhart, IN. There part numbers are;
P/side # 02-AZ-CL07-PBC-R-A
D/side # 02-AZ-CL07-PBC-R-A
If you order them from our parts department the part numbers are;
HEADLIGHT, WITH LED RH (PASS SIDE) SEALED, FR3 ONLY # 20X43340A
HEADLIGHT, WITH LED LH (DRIVERS SIDE) SEALED, FR3 ONLY # 20X43394A
I believe they were the same headlights that Chevy used on there trucks in 2012 or 2013.
Headlight replacements without LEDs, but with bulbs that allow you to see
Name:	ImageUploadedByForest River Forums1446855258.454589.jpg
Name:	ImageUploadedByForest River Forums1446855301.171693.jpg
b1barnes is offline   Reply With Quote
Old 11-06-2015, 07:16 PM   #63
b1barnes's Avatar
Contact FR and ask for replacement free.
Old 11-06-2015, 08:02 PM   #64
Greg-Gabe's Avatar
Thanks Chris! I finally downloaded the manual, we're heading for Paso in the morning and I'll give it a try. Dry run just now worked so hopefully we'll be able to watch the new "toad" and lane changes will be easier....
Greg-Gabe is offline   Reply With Quote
Old 11-09-2015, 08:27 AM   #65
side cameras
Please help. I have a 2014 Georgetown and EVERYTIME we go anywhere my side cameras fog up within an hour of traveling. What can I do?
kkopperl is offline   Reply With Quote
Old 11-09-2015, 08:39 AM   #66
I think is pretty cool that a Rep would help out members. I hope it can be expanded to cover other units such as my Coachmen Mirada or at least the ability to pass on the information and follow up with an answer. That would be a minor KUDO for Forest River
Bob & Sue Rowan
Okeechobee, FL
2012 Coachmen Mirada 29DS (SOLD)
2015 Keystone Bullet Travel Trailer
2016 F-150 Lariat with Auto Trailer Backup
Dog = Morki (Yorkie-Maltese) - Zoe
Malabarbob is offline   Reply With Quote
Old 11-09-2015, 08:45 AM   #67
foggy side cameras
every time I travel my side cameras on my 2014 Georgetown get fogged to the point they are useless. I need a solution please.
Old 11-09-2015, 01:46 PM   #68
Commercial Member
Rear camera question. We have a 2016 FR3 30DS with the Pioneer AV system. Is there a way to set rear back up camera to stay on? I would love to keep an "eye" on the toad!
There should be a setting that you can adjust on the setting menu in the stereo, also check to make sure your camera icon in the stereo is turned on. The icon should be located one the bottom footer of the stereo screen when you press the apps button of the middle button on the right hand side. the system menu should look like a gear. I hope this helps
FR3Eric is offline   Reply With Quote
Old 11-09-2015, 01:51 PM   #69
Commercial Member
Have you had a dealer look at the issue? I am not familiar with the camera system the Georgetown product uses, but that would be where I would start. Is the lens fogging from the inside or is it fogging from the outside?
Old 11-09-2015, 01:56 PM   #70
Question Black tank flush system
Hi Eric,
Could you please reply to the question I posted on 11-02-2015 at 11:52 A?
Thanks,
Chris
See post #43
2016 FR3 30DS
