Old 06-28-2018, 03:44 PM   #1
Atwood A/C Thermostat
Is there a fuse for the thermostat? The a/c is running but there is no power to the thermostat .
GM_LA is offline   Reply With Quote
Old 06-28-2018, 03:50 PM   #2
Head Rambler
If the A/C is running there has to be power to the thermostat.
How did you determine that there is no power to it?
It could have power and just the display board is out so it's not lighting up.
Gotta go campin!
Old 06-28-2018, 03:58 PM   #3
The unit doesn't shut down when I press the off button.
Old 06-28-2018, 04:10 PM   #4
Head Rambler
I bet it has power, but the display/button board is bad. Probably going to need a new thermostat.
Gotta go campin!
Old 06-29-2018, 05:59 PM   #5
Arvee Pilot
Old Oregoner's Avatar
What model coach?
Not to insult you, but do you have a coach with dual A/C units? If so, you have two thermostats, so one could be off and the other running.
Old Oregoner is offline   Reply With Quote
Old 06-29-2018, 07:56 PM   #6
Have you tried the remote control?
DutchRv is offline   Reply With Quote
Old 06-29-2018, 09:16 PM   #7
Thanks everyone!
It turned out to be a bad splice in the red wire inside the A/C
UNIT going to the thermostat.
thermostat
