Old 05-27-2018, 11:10 AM   #1
Jim Wiemels's Avatar
Atwood Air conditioner Error Code E4
Today, the first time using our 2016 30DS A/C and it will not run and displays an error code E4. Just wondering if anyone else has had this issue with the Atwood 15,000 BTU unit ? Thanks. Jim
Jim Wiemels is offline   Reply With Quote
Old 05-27-2018, 11:16 AM   #2
Jlreeves's Avatar
Manual says insufficient refrigerant. That’s not good.
2015 FR3 30DS Motorhome
2017 PrimeTime Crusader 315RST 5th Wheel
2002 Thor Chateau Sport Class C
Good SAM # 807510227
FROG # GA-0056-236
FMCA # F471293
Jlreeves is offline   Reply With Quote
Old 05-27-2018, 11:37 AM   #3
It is not designed to add more either.
Old 05-27-2018, 06:55 PM   #4
Not that error code but leaking and rusting. Hope you're still under warranty have them replace it.
I had an authorized FR warranty repair shop closest by asses, order and replace the unit. Never left the RV at the shop, just half a day for the actual install...
Name:	SmartSelect_20180527-195036_Adobe Acrobat.jpg
DutchRv is offline   Reply With Quote
Old 06-30-2018, 10:02 AM   #5
We had this same code just last weekend and found the breaker in the RV was tripped. Reset breaker and all was good even though it said E4 error code.
Sent from my VS987 using Forest River Forums mobile app
McDowelb is offline   Reply With Quote
Old 06-30-2018, 11:34 AM   #6
HortMi's Avatar
On mine I found if I unplug shore power with the ac on and plug in again I get that error code. I shut the system down and then turn it back on and everything is OK. I learned to shut the AC off before I unplug or switch from shore to generator.
HortMi is offline   Reply With Quote
air conditioner
