Originally Posted by cnower
How do you tell if a unit has or does not have a heat pump? Is the model number under the cover? I have a 2017 32DS both wall mounted controllers inside for each a/c are identical. New to the heat pump idea but now I am intrigued. Thank you for any info.
While I haven't looked myself on our newly installed Atwood AC in the rear, I know on our Dometic AC unit in the front, you can pull down the interior trim/filter cover and look up from the bottom. You'll find a label that'll have a PN and/or a 13.5k/15k specified. From the top of the RV, I think there is just 4 screws that hold down the exterior shroud, might be easier to do that...
The specs online for a 32DS aren't very clear, so you could have a 13.5k unit in the rear (which I'd expect for them to save $$$), which would be a non-heat pump version. Front unit is advertised as being the 15k with heat pump though.
