Old 04-17-2017, 10:06 PM   #1
Automatic stairs not lowering
The automatic stairs on my 2014 FR3 30 DS will not come down. Is there a recall on them?
Sgtmac is offline   Reply With Quote
Old 04-17-2017, 10:08 PM   #2
SeaDog's Avatar
check the condition of your starting battery
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-18-2017, 10:55 AM   #3
Do you have the switch off .. I know that's obvious to most but not to us when we were nebies
colourful64 is offline   Reply With Quote
Old 04-18-2017, 11:24 AM   #4
From what I remember, I think they are wired directly to your coach batteries. Check the inline fuse.
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 04-18-2017, 11:44 AM   #5
bubbles's Avatar
The steps power switch position has no affect on whether steps extend or not (only used for retracting/not retracting with engine off). The controlling factor is the door switch (on the door jamb) actuated by a magnet on the screen door. if you have Kwikee steps (I believe you do) that door switch must open when the door is opened (the magnet on the door is not adjacent to the switch). As said the power fuse is an inline 25amp directly from the coach battery.
Old 04-18-2017, 11:50 AM   #6
hammer55's Avatar
my non-lube steps were rusted to where they would not come down
Mark & Annie
2014 COACHMEN PURSUIT 27 KB
Modesto, Central California
hammer55 is offline   Reply With Quote
Old 04-18-2017, 12:08 PM   #7
SeaDog's Avatar
Let the forum know what you find and how you fixed it
Retired Navy
Old 04-18-2017, 12:19 PM   #8
bubbles's Avatar
The steps has an amber light that will come on for a short time when the steps extend. If that light is coming on for you then the door switch is working OK. The light is underneath on the steps mounting frame. Good luck.
Old 04-18-2017, 05:30 PM   #9
Wiring
I had this issue last year. The way the installer ran the wire it got pinched by the folding part of the steps until it finally cut the wire. The fix was easy by rerouting the wire.
punkutsu is offline   Reply With Quote
