Old 11-18-2015, 08:20 PM   #21
papap's Avatar
Vent pipe should go all they way out roof. Hard to believe water would get back in camper that way.
2016 Forester 3171DS
Work 28 and 28 around the world.
Camp every chance we get
papap is offline   Reply With Quote
Old 11-18-2015, 08:24 PM   #22
Left Coast
breather pipe is outside, right? If it's a light rain,might not be hard enough to make leak as there is no pressure forcing water......only way water can get to the inside of skylight would be if it's cracked or the caulking around it is bad
Old 11-19-2015, 02:13 PM   #23
Rvdixie's Avatar
You need to discount the water around your skylight as having anything at all to do with the blank tank flush operation. Even if the check valve under the cabinet was faulty how on earth would the water spray out of the cabinet and then go up to spray the skylight. Your description of the problem with the black tank is a bit too fuzzy for me to understand. Sorry. Why would you back flush the tank until it is full anyway. That's not necessary. I back flush all the time and time it so I have about a half tank and then open the valve on the flush gadget. I night repeat it several times until the water comes out clear.
Richard Charron
Zephyrhills, FL
2015 Ford F150 Eco Boost
2016 Coachmen Chaparral Lite 29MKS
Rvdixie is offline   Reply With Quote
Old 12-13-2015, 11:48 PM   #24
RetiredRVer
Originally Posted by bob caldwell View Post
Think it's your check valve in the tank flush line....possibly located in sink cabinet
Sounds like Bob has it correct....this valve has been replaced twice (under warranty) in my 282RK. Next time I'm going to replace it myself with an all brass valve.
checkmate99 is offline   Reply With Quote
black, black tank, tank
