Old 08-05-2019, 10:44 PM   #1
Edmo's Avatar
Bathroom Odor
Up until yesterday there have been no odors in our 2016 30ds. Itís seems that there is urine odor coming from around the toilet. I checked the vent on the roof and it seems unobstructed. I also flushed the black water tank at the end of the trip as well as thoroughly cleaning in and around the bowl.
Any ideas or comments ?
Thanks,
Ed
Edmo is offline   Reply With Quote
Old 08-05-2019, 10:51 PM   #2
If you have a Model 300 Dometic toilet that will probably be your problem. Look on the side of your toilet and if it is a Model 300 get the sn and call Dometic.
There are a ton of posts on this forum about defects with this toilet where it collects liquid between the bowl. I had a 300 and they replaced it.
2016 Siverback 33IK
Old 08-05-2019, 11:12 PM   #3
Edmo's Avatar
Okay, thank you
Old 08-05-2019, 11:13 PM   #4
Edmo's Avatar
Where is the s/n located please
Old 08-05-2019, 11:18 PM   #5
It should be on a sticker on the side of your toilet. It has been a while but I think on right hand side. This might help... https://www.edometic.com/h.nsf/model...g_location.pdf
2016 Siverback 33IK
Old 08-05-2019, 11:19 PM   #6
Iíve found it is a lot easier to stick your phone down there and take a pic instead of getting on your hands and knees and trying to read...lol
2016 Siverback 33IK
Old 08-05-2019, 11:26 PM   #7
If it is all plastic it is a 300 and Dometic will replace it or let you upgrade at a reduced price.
yensidcamper is offline   Reply With Quote
Old 08-06-2019, 12:08 AM   #8
If you are camping and need to get a little relief from the odor you can try what I did. Look in the back of the toilet and you will see an opening. I poured some tank deodorizer in that hole to reduce the odor. I donít know what you use in your black tank but add some to that cavity and it may tone it down until you can get the unit replaced.
2016 Siverback 33IK
Old 08-06-2019, 08:06 AM   #9
I had mine replaced I spent 50 for the 310 with wood seat and soft close they threw in a cleaning sprayer. Dealing with dometic was great
Iankerr is offline   Reply With Quote
Old 08-06-2019, 08:12 AM   #10
Edmo's Avatar
Thank you all, it is a plastic toilet and I really didnít expect this one as I havenít had one issue for 3 yrs. Once again the forum family came through. Will keep everyone appraised of my conversations w Dometic.
bathroom, roo
