Old 07-08-2015, 03:41 PM   #1
twojump36's Avatar
Batteries Dead after 2 weeks
Brand new FR3 30DS with 14 miles on it...
I went out of town for a couple weeks and today I had to get something out of it.
I had not flipped the disconnect switch to kill all the power, but everything was turned off. When I left, the batteries were fully charged and the coach was unplugged.
The weather up here in Oregon has been hot... mid 90's (hot for here)
When I opened the door, I Heard a clicking sound from somewhere under the coach by the steps.... but the steps would not come out or extend.
I crawled up in the coach and went to the control panel by the bathroom. everything was dead. I checked the lights... dead...
I put the key in the ignition and started the engine, and I heard a clicking noise (mid coach)... With the engine running I went back to the control panel and everything was functioning normally now. I checked the steps and they went out... I checked the battery level and it says 75% charged...
I turned off the coach and everything is functioning normally still.
I called the service shop where I bought this thing and they guy there says that I should have turned off the battery disconnect switch... he said the batteries can be discharged by the electronics and the Co2 sensor...
I call BS.... there is no way that those two things could discharge those batteries in less than 2 weeks....
My questions....
Is there a safety shut-off for the batteries if the coach is not being used and it gets hot (think mid 90's)?
Has anyone ever experienced this before and what did you do?
twojump36 is offline   Reply With Quote
Old 07-08-2015, 03:59 PM   #2
RSchleder's Avatar
I have owned 12 Rv's including 3 diesel pushers and I have never seen a auto battery disconnect that disconnects the battery when they reach and certain level of discharge. Every battery disconnect I have ever had (or seen) is a manual switch that cuts the 12v off when manually toggled. Also, the best way to find out what's draining the batteries is to put a meter across each fuse and read the level of "draw" on each/all circuits. This will tell you exactly which circuit is drawing from the battery and how much the draw is.
Days camping (2016)----181 days
Days camping (2017) --- 82 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
11 different RV's
RSchleder is offline   Reply With Quote
Old 07-08-2015, 04:02 PM   #3
KyDan's Avatar
Turn off your battery switch and your batteries will not go dead!
The RV mech was correct.
It's common.
Sometimes the easy answer is the correct one!
Happy Trails!
Peace!
Dan & Rita D
Blue Ox WD hitch
Old 07-08-2015, 04:05 PM   #4
TURBS's Avatar
It's common.
Happy Trails!
X2
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "11 nights"
Old 07-08-2015, 04:07 PM   #5
clr
With the LP detector and the vampire loads in the radio and such you easily have a half amp load, I would guess more. So if you take the half amp per hour times 24 hours you get 12 amp hour per day of load. If you are gone 14 days that is a total load for that time of 168 amp hours. Most units only have one battery so you may only have 105 amp hours in the battery. So yes you would be deader than a door nail in that period of time.
clr is online now   Reply With Quote
Old 07-08-2015, 04:11 PM   #6
Flybob's Avatar
Put a battery tender on it, plug it in to shore power or add a disconnect switch. Two weeks of parasitic draw will kill the battery.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 07-08-2015, 05:49 PM   #7
HAPPY WHEN RV'ING
drivmsafe's Avatar
The service tech is correct. I've had my batteries go dead after a couple of weeks. Unless you switch off the battery disconnect, you'll have a small drain. When I know we're not using the coach for a while I always either plug into my shore power or use my battery tender.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 07-08-2015, 05:53 PM   #8
crunchman12001's Avatar
Originally Posted by TURBS View Post
X2
TURBS
2011 32bhok Sabre
X3
crunchman
2015 F-250 FX4
Old 07-08-2015, 08:00 PM   #9
Technorick's Avatar
CLRs math is correct. And (on my 30Ds) the vampire loads are not off when you shut off the switch. The LP gas safety solenoid is a good example.
Even if you shut off the switch these loads will drain the coach batteries.
If yo cant plug in via the cord use a battery tender that will trikle charge the house batts. The unit comes with an plug that can be connected permanently to make it easy to quick disconnect.
2014 FR330 DS
Technorick is offline   Reply With Quote
Old 07-08-2015, 08:57 PM   #10
bigduke1956's Avatar
would starting the motor every day mitigate this drain, how long should the motor run? In storage conditions, do you disconnect batteries?
Mike & Sun
Pets - Piotti, Kongatti
2016 Georgetown 369 XL
US Army 22 years
Days Camped
2015 - 50+ days
bigduke1956 is offline   Reply With Quote
battery
