Old 07-05-2016, 10:27 PM   #1
Battery upgrades
Has anyone upgraded the battery system in their FR3? If so, what did you do?
teamjendy is offline   Reply With Quote
Old 07-06-2016, 09:36 AM   #2
Prime Member
I don't have an FR3 but I did upgrade my batteries to a pair of 90ah deep cycles.
Sent from my SM-G900V using Tapatalk
2016 Coachmen Freedom Express Liberty Edition 310BHDS
2013 Chevy Silverado 2500HD LTZ 6.6L V8 Duramax
Husky weight distribution hitch with sway control
timfromma is offline   Reply With Quote
Old 07-06-2016, 09:38 AM   #3
Kenny kustom's Avatar
The biggest that will fit, and the best you can afford/need.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
Old 07-14-2016, 09:05 AM   #4
lol .. which brings me back to my question.
what is the biggest/best i can put in a 25DS
Old 07-14-2016, 09:07 AM   #5
You asked.
http://www.amsolarrv.com/lbats/40s-vt-400-ess
2016 Sabre 36QBOK
Old 07-14-2016, 09:13 AM   #6
I need to learn more about these battery systems and how they function. Perfect source for me. Thanks.
2014 FR3 25DS
Old 07-14-2016, 04:30 PM   #7
HAPPY WHEN RV'ING
drivmsafe's Avatar
The only upgrade I"ve seen is someone went from 2, 12V batteries to 4, 6V. A new battery mounting plate would have to been made in order to hold the 4 batteries.
Hope this helps.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 07-17-2016, 08:14 AM   #8
wayne and sherry's Avatar
I neglected my 2015 FR3 30DS stock batteries, mostly because they are out of sight out of mind. mine were not only low on water but we're also dead dead dead... And for a long time. I yanked em out, cleaned em up, filled with distilled water, and used my buddies ship to shore charger. I nursed these battery's for 3 days with over night rests and I'm happy to say I've got them back and hovering around 78%. Not bad for the long dry dead period of about 6 month with most of that time being winter.
wayne and sherry is offline   Reply With Quote
Old 07-17-2016, 09:09 AM   #9
Just for knowledge sake, the portion of the plates that were uncovered in acid, are now dead. If you're only using them sparingly, you probably won't notice it, but if you dry camp much, you will. The test would be, put a load on them from the 78% you believe them to be maintaining, and then after a short time, re-test. That will give you some idea, how much functional utility your dealing with.
Old 07-17-2016, 09:57 PM   #10
Landshark1's Avatar
When I got my 30DS, I added solar, and when I did that, I removed the original 2 - 12V house batteries and installed 4 - 6V batteries. I did have to install another battery holder for the extra batteries. The reason being that from what I've read, battery longevity favors the 6 Volt batteries. My understanding is that a major cause of deep cycle battery failure is the shedding of active material from the battery plates and the 6 volt batteries have thicker plates. I'm no expert on the subject, but that's what I ended up doing.
Landshark1 is offline   Reply With Quote
battery, upgrade
