Old 08-13-2016, 06:18 PM   #1
BBQ off house tank
I know there are numerous ways (and threads) to do this, but this is what I came up with.
Coleman Roadtrip LXE. Took the brass connection from the grill's regulator. The regulator is not needed anymore. Reducing bush 1/4 x 1/8 to connect a Camco Quick Connect plug.
Tee off the existing line AFTER the RV Tank's regulator. This way the grill's regulator isn't needed, plus the pressure in the line to the grill is low.
Had a 15 feet hose made, 1/4 mntp on both ends. Connect one end to the tee, the other end to the quick connect, which you can connect to the grill!
Grill wherever around the coach
PS: Grill works as it should, and no pressure issues using appliances in coach when grilling, or vice versa.
ID:	117145   Click image for larger version
ID:	117146   Click image for larger version
DutchRv is offline   Reply With Quote
Old 08-15-2016, 10:25 AM   #2
How do you store the 15ft hose? I've thought about going to gas grill, though I do like the charcoal...
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
Old 08-15-2016, 10:34 AM   #3
I store it neatly rolled up and tied to the frame above the tank. Plenty of space.
I will probably add another quick connect, so I can store the hose inside a bin somewhere else.
By doing so I officially have spent more on hoses and connections than on the grill itself. (didn't tell DW)
real men grill on LP
Old 08-18-2016, 02:35 AM   #4
Landshark1's Avatar
I finally ditched the gas BBQ, (it never cooked evenly anyway) in favor of a Traeger PTG+. So far this has been the best BBQ I've ever purchased. It burns wood chips instead of gas. All you do is add the wood into the hopper and plug it in, and the flavor is unmatched by any RV BBQ I've ever used. It fits perfectly in the outside storage bin. My next project is to install a slide for it.
Name:	ImageUploadedByForest River Forums1471505653.213680.jpg
Landshark1 is offline   Reply With Quote
bbq, tank
