Old 12-27-2015, 11:23 AM   #1
Black Streak Magic Potion
Does anyone out there claim to have the magic chemical to remove the blackish streaks that come from the gutters. I tried what worked on the boat but marginal success. I got the body clean but the decals still show it.
Thanks to all , Hope your Holiday Season is going well.
Grumpy Guy is offline   Reply With Quote
Old 12-27-2015, 12:22 PM   #2
grumpy0374's Avatar
I know it's going to sound weird, but try Dow Scrubbing Bubbles Bathroom Cleaner. Works better than any black streak remover
It's also the best stuff I've found to remove bug guts, dead bugs, bird poo.
Just spray it on a surface out of direct sun, let it work fro 5 minutes, than brush it off with a wet brush. Lot easier to use with a soft brush on the end of an extension handle than trying to balance on a ladder using a dryer sheet.
Been using it for awhile now, and it dosen't hurt paint or graphics, plastic or rubber.
Grumpy
grumpy0374 is offline   Reply With Quote
Old 12-27-2015, 02:03 PM   #3
Todouble's Avatar
Awesome cleaner takes them right off. Found at any dollar tree, dollar enteral, walmarts....
Todouble is offline   Reply With Quote
Old 12-28-2015, 12:26 AM   #4
WD40 works.
Albert1950 is offline   Reply With Quote
Old 12-28-2015, 11:41 AM   #5
Stormrider151's Avatar
x2. Just follow the directions. It's cheap too.
Stormrider151 is offline   Reply With Quote
Old 12-28-2015, 12:04 PM   #6
Lloydg's Avatar
Send a message via AIM to Lloydg Send a message via MSN to Lloydg Send a message via Yahoo to Lloydg
Be careful using kitchen/bathroom types of cleaners on your RV. It can remove your wax finish and the UV protection they provide. I only use black streak removers made especially for RV's and found they all work well.
Heartland Big Country 3150RL
2013 Ford SD F250 4x4 SC; 6.2
Reese 18K Elite w/slider - Ada, Michigan
Lloydg is offline   Reply With Quote
Old 12-28-2015, 01:52 PM   #7
I use a cleaner called reliable, spray on wash off. It's the best cleaner I have found next to Greased Lightning or Simple Green. Reliable can be found at any RV store
No more shoveling is offline   Reply With Quote
Old 12-28-2015, 02:01 PM   #8
Seasonal's Avatar
LA Awesome from the dollar store works great and no elbow grease needed.
Ford 2015 F250 Crew Lariat Ultimate 6.7L Diesel 4X4
Seasonal is offline   Reply With Quote
Old 12-29-2015, 06:01 AM   #9
grumpy0374's Avatar
Of course Scrubbing Bubbles will remove wax. So does Simple Green, Awesome Cleaner, Crud Cutter, and any other strong de-greaser that has been named. Even the repeaqted use of dryer sheets will remove wax.
I've never found an rv rated black streak remover that will completely remove black streaks after they've been on awhile. They all seem to leave a "shadow" of the streak.
As for bug guts, you don't think anything strong enough to soften them up won't remove wax?
As far as the Scrubbing Bubbles, it is safe to use on any surface in a bathroom, from plastic to glass, tile, ece ect ect, and I've found it does not harm decals, rubber, paint, plastic, vinyl on my Lexi.
Simple fix...go over the area after it's cleaned with some Turtle Wax Ice. Goes on very easy and wipes off easy. I can do my Lexi in an hour.
Grumpy
Old 12-29-2015, 06:49 AM   #10
I found using siding cleaner from Home Depot works pretty good, pour some in a spray bottle and apply it, with light rubbing if needed and a rinse the streaks are gone.
2005 GMC Sierra 2500HD 6.6L, Air bags
2012 Sabre 31RETS
snipe is offline   Reply With Quote
black
