Old 09-06-2016, 12:43 AM   #1
Black tank flush
Fr3
Whats the best way to flush the black tank. Valve open? Or keep it closed for a little and than open the valve.
Nsopti is offline   Reply With Quote
Old 09-06-2016, 12:53 AM   #2
Originally Posted by Nsopti View Post
Fr3
Always keep the black tank closure to the open position when showering the tank on the clean out. If you don't you could wind up getting black water up into higher sources of the tank that could be harder to clean, not good.
BALLZITCH is offline   Reply With Quote
Old 09-06-2016, 01:00 AM   #3
Fr3
close drain valve, spray for a while, shut off spray, open valve and let it flow out, repeat until you're satisfied with the cleanness,....BECAUSE,... if your in-the-tank spray nozzle is mounted like mine(most are), it is mounted on the drain side of your black tank just above the drain hole,.... if you are spraying while you have the drain valve open and letting the stuff flow out, .... the spray is spraying into/against the flow of the stuff trying to flow out the drain, and actually hindering that flow towards the drain hole,..... FR must mount them there because its convenient and easier, if they mounted the spray unit on the opposite side of the tank, that spray would actually help push the flow towards the drain hole, but they don't.....
if you can determine that your flush unit is mounted on the opposite side of the black tank from the drain side, then ignore what I just posted, but it probably isn't.......
fella10 is offline   Reply With Quote
Old 09-06-2016, 10:48 AM   #4
I run ours with the valve open for the first drain, then I do it with the valve closed. I did some testing the first time and determined that it takes a little less than two minutes for the tank rinser to fill the tank to 2/3. I repeat that as often as it takes for the water to drain clear(ish).
I try not to do other stuff while I'm backfilling the tank. I'm not a great multitasker at the best of times and this is one instance where I REALLY don't want to lose focus!
Restcure (formerly JD and Beastlet)
2012 Rockwood Ultra-Lite 2701SS > ProPride 3P 1400 > 2013 F150 FX4 SC EB LB max tow 3.73s
John, Dawn, daughter Emily and Bella the camping kitty
illegitimi non carborundum
Restcure is offline   Reply With Quote
Old 09-06-2016, 11:42 AM   #5
wayne and sherry's Avatar
For sure.
wayne and sherry is offline   Reply With Quote
Old 09-06-2016, 11:44 AM   #6
Canadian Member
itat's Avatar
X2
I let it run with the valve open for a minute or two and then close the valve and let it fill the tank until the full light starts to blink and immediately open the valve. Then I repeat once or twice.
IMO, the flusher's spray nozzle will clean a fair bit of the solids but not everything. Filling and draining again helps wash out what the flusher nozzle can't reach or doesn't push hard enough.
Here's a couple videos that I found helpful.
I also use the Geo Method to help keep the tanks clean and control odors. It makes the sides and bottom of the tank slippery to aid the flusher in getting the solids moving.
2011 Rockwood Signature Ultra Lite 8293SS, 12K Equal-i-zer
2016 Ford F-250 XLT SuperCrew, 6.2L, 4x4, 6'9" bed, 3.73
Fondly remembered:
2009 Ford F-150 XLT SuperCrew, 5.4L, 4x4, 5'6" bed (2012 - 2016)
Old 09-06-2016, 11:59 AM   #7
+1!
black, black tank, black tank flush, tank
