Old 01-22-2020, 06:01 PM   #1
robo44's Avatar
Black Tank Flush
Been trying for awhile to get the black tank flush to work on my 2019 FR3 33DS.
I feel I may have a bad check valve or something preventing water to enter the black tank -
(I use a clear elbow so I can see when water leaves the tanks) No water Ive never been able to use it and water will not flow into the tank.
Any advice on possible culprits to check?
Of course, I assume the FR3 has a check valve someplace that may be blocked or not working -
2019 FR3 33DS Motorhome
650 Watts Solar, 400Ah LIFEPO4, 2000 Watt Inverter, 40A DC/DC Charger, SumoSprings, Roadmaster Steering Stabilizer, BlueOx Trac Bar, Truma AquaGo WH, NVIDIA Shield TV
Days Camping
2019 57:2020 20:2021 30:2022 46:2023 47:2024 7
robo44 is offline   Reply With Quote
Old 01-22-2020, 06:20 PM   #2
Mr. Dan's Avatar
Read through the following thread for hints. There are many such threads on this forum. This one has a picture.
http://www.forestriverforums.com/for...ve-196000.html
Old 01-22-2020, 06:41 PM   #3
2014 XLR 27HFS
dave961's Avatar
Mine wouldn't work at all and I bought it brand new. I too thought it was a bad check valve. Found that behind a panel, took it apart, put it together, it tested fine. So I crawled under the camper, located where the line came in from the outside of the camper and followed it. The factory monkeys had zip tied it in a tight 180 degree bend. I cut the zip tie, but the pex didn't want to be round anymore. I moved the pipe to give it room and forced it round with pliers and zip tied the kink to keep it round. Then the flush worked great, and still does 6 years later.
ID:	222240   Click image for larger version
ID:	222241   Click image for larger version
Dave & Audrey
dave961 is offline   Reply With Quote
Old 01-22-2020, 06:48 PM   #4
robo44's Avatar
Perfect ! Thank you ...exactly the help I was looking for and a point in the right direction
Days Camping
Old 01-22-2020, 06:54 PM   #5
Librarianocnj's Avatar
My black water connection they pinched between the frame and floor of trailer. It’ll only take Forest River 3 months to fix it.
2019 Cherokee Grey Wolf 29TE
2018 Ford 150 SCAB STX 3.5 EB
Librarianocnj is offline   Reply With Quote
Old 01-22-2020, 09:05 PM   #6
There have also been reports here of the flush check/antisiphon valve being plumbed backwards.
Days Camped '19=118 '20=116 '21=123 '22=134 '23=118 '24=90
Old 03-20-2021, 04:01 PM   #7
robo44's Avatar
Im going to start this up again and hope more FR3 owners can chime in. My black tank flush is still not working, never has. I had some time to try to locate the Check Valve.
I've searched everywhere I could reach and see. I check the bathroom, I check behind the wetbay. I checked the kitchen. All no luck in finding the Check Valve.
Before I twist myself into knots and try to access the location behind the toilet in the false wall or Washer/Dryer area any other suggestions from FR3 owners where one might find this check valve where YOU have seen it.
Odds are if you own a FR3 of 2017-2020 it might be in the same location.
If you own an FR3 and know where your Check Valve is, please let me know and pictures are appreciated.
Thank you
Days Camping
Old 03-20-2021, 07:23 PM   #8
rk06382's Avatar
Thank you
I don't know where mine is, but it is working.
The backflow valve by code needs to be higher than the toilet seat. I suspect mine is behind a panel under the bathroom sink.
Robert
2018 FR3 28DS | Boondock 99% of the time
Samlex EVO-3012 Inverter/Charger | 600ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | SnapPads | SumoSprings | Koni Shocks | RVLock
Solar Power & Battle Born batteries
rk06382 is offline   Reply With Quote
Old 03-21-2021, 10:36 AM   #9
robo44's Avatar
Wish mine did... Having one bear of a time locating mine... Not to many places higher than the toilet. You don't think they would install it behind the shower where I'd have to remove the panelling?
Days Camping
Old 03-21-2021, 10:39 AM   #10
Mine was way up behind the kitchen sink. It was installed backwards. A little tricky to get to it.
yensidcamper is offline   Reply With Quote
Old 03-21-2021, 10:44 AM   #11
We've had reports of other brands being behind the shower wall.
They had to remove the shower faucets to get to the anti-siphon/check valve.
Old 03-21-2021, 02:37 PM   #12
robo44's Avatar
Thank you ..I will recheck there
Old 04-01-2021, 04:50 PM   #13
robo44's Avatar
I wanted to circle back and let ya'll know I finally found the check valve for the Black tank flush.
Somehow I missed it, is located under the bathroom sink, however it was zip tied to the back side of the drain where I could not see or feel it.
So, now that I found it, my black tank flush still does not work i put a hose to the input (in my wet-bay and turned the water on.... nothing enters the black tank for over 15min no water, zip nada
Suggestions???
Should I replace the Check Valve? Any suggestions on what one on Amazon are there better quality ones vs OEM?
Assume that does not solve the issue what other things can I look at before I take drastic measures..
Thank You
Days Camping
Old 04-01-2021, 04:56 PM   #14
Did you look to see if it was plumbed backwards? They are one way valves.
Did you connect the outside hose to the flush port, (don't turn on yet) go inside and pull the input line off the valve, put it in a bucket, have someone slowly turn on the water and see if water gets at least that far?
Old 04-01-2021, 04:56 PM   #15
Rover Podder's Avatar
It's common on some models for the black tank check valve to have been installed backwards. You might want to check to ensure that the inlet is on the correct side.
2020 rPod 180
2017 F-150 XLT SuperCab 2.7 EcoBoost
Rover Podder is offline   Reply With Quote
Old 04-01-2021, 04:59 PM   #16
bubbles's Avatar
Suggestions???
Thank You
Pull it out and just see if you can blow hard through it in one direction.
Old 04-01-2021, 05:00 PM   #17
robo44's Avatar
Will check that.. thank you
Days Camping
Old 04-01-2021, 05:01 PM   #18
robo44's Avatar
Good point .. thanks for the advice
Days Camping
Old 04-01-2021, 07:41 PM   #19
bubbles's Avatar
Actually, now that I think about it I don't think one could blow through it because of the small check valve ball bearing. It will take water pressure to check it out. Disregard the blowing.
Old 04-01-2021, 11:16 PM   #20
robo44's Avatar
Will do!
Days Camping
black, black tank, black tank flush, flush, tank
