Old 01-18-2017, 03:02 PM   #1
Blew LED fuse, where is it?
Was rebuilding the front speaker housing with .5 MDF to get rid of the rattling 'cardboard wood', and I shorted the cockpit LEDs for a sec and probably blew a fuse. Where is it?? Everything else works, also the dimmer switch that also controls the brightness of the cockpit lights.
Anybody??? Inline fuse maybe?
Perhaps I banged up the timed relay that controls those LEDs?
ID:	128253   Click image for larger version
ID:	128254   Click image for larger version
DutchRv is offline   Reply With Quote
Old 01-18-2017, 03:18 PM   #2
2015 28DS btw...
once again, everything else works, awning LEDS everything...
Old 01-19-2017, 08:34 PM   #3
found it fixed it.
Fuse #10 (10amp) in block under dash on left side. ATM 10A (mini) Blade Fuse.
See very helpful documentation attached.
File Type: pdf FORD 2015 FR3 MODELS FUSE BLOCK DIAGRAM.pdf (262.2 KB, 49 views)
fuse, led
