Old 04-03-2018, 03:50 PM   #1
Boondocking
I have a2018 fr3 30ds how do I add water to water tank while boondocking
Hdbennjr is offline   Reply With Quote
Old 04-03-2018, 03:54 PM   #2
Lacey's Spring, AL
formerFR's Avatar
how do you add water from 'what'? a spigot? a bucket?
formerFR is online now   Reply With Quote
Old 04-03-2018, 03:59 PM   #3
Bucket
Old 04-03-2018, 04:01 PM   #4
Lacey's Spring, AL
formerFR's Avatar
does your unit have a 'winterize/sanitize' lever or handle in the wet bay?
Old 04-03-2018, 04:06 PM   #5
Lacey's Spring, AL
formerFR's Avatar
looks like you should have 'fresh tank fill' which may use your water pump to pull in water from an outside source, such as a bucket, creek, pond, etc. At least that's the only thing that makes sense for that 'label'. The other is 'City Water', which is when you connect to a pressurized water system, like a water spigot.
The other is to use pressurized water to help wash out your black tank.
Old 04-03-2018, 04:17 PM   #6
No my unit has aregular hose attachment in the wet bay for the fresh water refill.I have discovered that it requires pressure to add water. Would a portable water pump wrk to transfer water from water juggs
Old 04-03-2018, 04:20 PM   #7
Is there some reason why you didn't fill the freshwater tank at home? Most of us would do exactly that!
Schvarak is offline   Reply With Quote
Old 04-03-2018, 04:22 PM   #8
I was dry camping and had exhausted my water supply the rig was full upon my arrival
Old 04-03-2018, 04:44 PM   #9
Post a close up picture of the water management panel (aka docking station, wet bay...). There may very well be a way to arrange the valves and use the pump to "power fill" the tank.
LegacyFB38 is offline   Reply With Quote
Old 04-03-2018, 09:39 PM   #10
Two of my neighbor's 5th wheel's won't draw water from a bucket from their "water" station. A little bit of water pressure seemed to fix the issue.
Here is what I use:
12 volt marine (water) pump. I got mine form harbor fright but other vendors have the same one. https://www.walmart.com/ip/TruePower...&wl13=&veh=sem
7 gallon aquatainer https://www.amazon.com/dp/B001QC31G6...a-309679368222
Garden hose quick disconnects: https://www.homedepot.com/p/Camco-Qu...FVUpaQodv-MLpg The male quick disconnect is heated with a torque and then screwed into the aquatainer cap. The thread on the quick disconnect does not match the thread on the cap which is for a spigot. Heating the male quick disconnect fitting melts the plastic and allows you to get your own threads and ensure a leak free seal. First time I did this, I forced the quick disconnect on and cross threaded it. The cap eventually split; has been good for years using heat.
Use a white water hoses to feed the pump and run pump output to fill hole or your water "docking" station.
12 volt power sources for pump: At first I used a portable battery jump starter, then I used my ATV cigarette lighter power, and occasionally the 10 amp output from my generator. I now have permanent power in a weather proof aviation plug mounted on my exterior wall next to my fresh water gravity feet hole. Makes the whole power issue a non-issue now.
We also put a little water sanitizer in each water jug. While it does make the water smell and taste bleachy we found it allows us to extend showers two 2 days when boondocking. The bleach does a good job killing body bacteria responsible for body odor. Its no stronger then swimming pool water.
No, we don't drink the water from the camper's FW tanks and only drink pure distilled grain spirits. “Do you realize that fluoridation is the most monstrously conceived and dangerous communist plot we have ever had to face?” I have this information from a good authority, Brig. General Jack D. Ripper who I served with in the Army.
Skyliner is offline   Reply With Quote
boondocking
