Old 01-09-2016, 01:27 PM   #21
Former Full Timer
Duckogram's Avatar
Suggestion: The line that water comes out of when the pump is on (or not) is the low point drain. There should be a seperate low point drain for hot and cold. The pump only pressurizes your system after the water tank. The water tank has a gravity only drain. It is just a hose so the possibility of a kink exists. That hose is always lower than your water tank. Unless the factory never installed one! Here is a pic of what you are looking for. Left white is cold low point. Center red is hot low point. Right white is FW tank drain. Note how the FW drain tee's off to the water pump inlet.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 01-09-2016, 06:01 PM   #22
Originally Posted by Cigarman View Post
Congrats on your purchase! We purchased our 2016 30ds in June and love it as well. Very happy and have had zero issues so far and have put about 4000 miles on it with many days of camping. Added a few shelves and fantastic fans in the bedroom and living area. Got a small blue ray player at Costco for about 40.00 and it now dwells in the bedroom. Now just counting the days to good weather so we can be off again.
Hey Cigarman, we are in Florida right now, camped out at Sherwood Forest for a couple of weeks then back to Orlando, this is our first big trip out, coming from NJ are you Guys anywhere in the area?
jkillesr is offline   Reply With Quote
Old 01-09-2016, 10:01 PM   #23
Rolling Magic's Avatar
Even with their problems, they are still a fun and enjoyable rig to have. We have a 2014 and we been all over the western states. Have a fun time and enjoy!
Rolling Magic is offline   Reply With Quote
Old 01-13-2016, 05:18 PM   #24
Cigarman's Avatar
We could not be farther away!! Home in SW Washington waiting for some better weather. Have fun out there, spent 2 weeks in Florida in December for work (and a bit of golf)and missing that weather right now.
2016 FR3 30DS and a
97 Jeep Wrangler that follows me to close
Cigarman is offline   Reply With Quote
Old 03-22-2016, 04:55 PM   #25
pkenley's Avatar
Smile
Originally Posted by jimcarterhb1951 View Post
Congratulations, and welcome to the forum! I purchased my 2016 FR3 30DS in March, and have had a couple of issues as well, but overall I am thrilled with my purchase. I just installed a go power solar and inverter system and can't wait to try it out.
Can you give us some details on your Go Power Solar system setup??? maybe some pictures as well. TIA
Phil & Carla Kenley
2014 Rockwood ROO 21ss
2013 Ford 150 Platinum Crew Cab
(Looking at the Georgetown 329DS)
Nights camped in 2011/16; 2012/15; 2013/48;
2014/10; 2015/101 2016/55 yr to date
pkenley is offline   Reply With Quote
Old 03-22-2016, 06:06 PM   #26
GoPower Solar
pkenley...I had a transfer switch, solar controller, 3000 watt Pure Sine Wave Inverter with remote, and 5 GoPower 100 watt flexible panels installed. I will be mostly in the southwest so tilting is not a concern, and most people do not get on the roof to tilt panels anyway, unless camped for extended periods. I will be upgrading the two 12 volt coach batteries, to four 6 volt golf cart batteries sometime later this year.
Name:	control panel.jpg
ID:	102599   Click image for larger version
ID:	102600   Click image for larger version
Name:	solar panels.jpg
Jim Carter
2016 FR3 30DS
jimcarterhb1951 is offline   Reply With Quote
Old 03-22-2016, 09:28 PM   #27
from Cali
RV Pilot's Avatar
Looks good! I'm working on mine right now. I have three 150 W rigid panels. Where did you drop your wires down? I was planning on going through the angled wood in the pantry. Click image for larger version
Name:	ImageUploadedByForest River Forums1458699975.494712.jpg
ID:	102615Click image for larger version
Name:	ImageUploadedByForest River Forums1458700050.718623.jpg
ID:	102617Click image for larger version
Name:	ImageUploadedByForest River Forums1458700082.399627.jpg
2015 FR3 30DS
Central Coast of California
______________________
2015 FR3 30DS
2014 Jeep Rubicon X
RV Pilot is offline   Reply With Quote
Old 03-22-2016, 09:30 PM   #28
from Cali
RV Pilot's Avatar
Also how do you find the regeneration time in good son with the two 12 V batteries? I've switched over 2to 4 6 volts.
2015 FR3 30DS
2015 FR3 30DS
2014 Jeep Rubicon X
Old 03-22-2016, 09:56 PM   #29
I ran the wires down the refrigerator vent, and mounted the controller and inverter remote in the panel above the fridge.
Jim Carter
2016 FR3 30DS
Old 03-22-2016, 09:59 PM   #30
From what I can tell in a short period of use the regeneration and AH's are no way as good as 6 volt batteries, that's why I will be upgrading to four 6 volts when I get the cash. I also wanted to get some use out of the new 12 volts that came with the MH. Seemed a waste to throw them away.
Jim Carter
2016 FR3 30DS
motorhome
