Old 05-06-2015, 07:10 PM   #1
Canadians will freeze in a FR3
I now understand these FR3 are not dual pane glass and the floors are not insulated. But jeepers what is going on with the furnace?. It cant heat the darn motorhome... We are at plus 2 degrees. Two hours with the furnace on 31 degrees.. We have to keep the bathroom door open to get a little heat... So if the air.conditioner is no good in the summer and the heater is no good in the spring or fall... We just purchased a glorified cardboard box it seems
colourful64 is offline   Reply With Quote
Old 05-06-2015, 07:43 PM   #2
I've notice some of the complaints about the furnance, but we've just picked up our 2015 30DS and it got down to 40F at night in Colorado and we were toasty all night. Heat was blowing out pretty good at all the vents. One in the bedroom, one in the bathroom and two I believe in the kitchen/stairwell. I wonder what's going on....
KansasFR3 is offline   Reply With Quote
Old 05-06-2015, 08:44 PM   #3
Online_17's Avatar
As a Canadian, I can safely say, yes...FR3 is poorly insulated. Next cold night, try opening one of the closets on the bedroom ...Buurrrrrr!
Online_17 is offline   Reply With Quote
Old 05-06-2015, 09:23 PM   #4
Certified Curmudgeon
Is you ducting connected to the furnace. I found 2 of 3 disconnected however, I have never used the furnace other than to test it. Besides, Canadians will not freeze as they all come to florida when the snow falls.
Mike Dropped
Old 05-06-2015, 10:32 PM   #5
Was the fan on high?
b1barnes is offline   Reply With Quote
Old 05-07-2015, 12:21 AM   #6
We were told by the dealer The fan must be on auto for the furnace to work.. So yes we are getting lots of air blowing.. But its not that warm. So disappointig
Old 05-07-2015, 07:13 AM   #7
If your furnace is blowing cold air you could have an air lock in your gas line. This happened to us last winter after we topped off the propane tank. You should run all of your appliances on gas (stove, fridge, etc) for a bit to see if it clears out. Also, cycle your furnace on for a few minutes than off for a few. This worked for us. The furnace should be putting out warm air or there is something wrong. We used it at 28 degrees F outside and were fine.
wolfgang22 is offline   Reply With Quote
Old 05-07-2015, 08:18 AM   #8
I've been out in the low 30s in our 2014 FR3 without any problems with heat. Something is amiss with your coach if your coach can't warm you up. If it's new I wouldn't mess around - take it to the dealer while it's under warranty. If not under warranty call Forest River and complain. They might hook you up with a free service call to figure it out.
spicyrv is offline   Reply With Quote
Old 05-07-2015, 08:22 AM   #9
Rugged Brown's Avatar
Do not underestimate the toughness and resilience of a Canadian.
Terry/Bernadette
Lily the Yorkie
2019 Dodge Ram Sport 1500
2019 FR Vibe 28RL
Rugged Brown is offline   Reply With Quote
Old 05-07-2015, 08:28 AM   #10
Ret E-9 Anchor-clanker
donanddona's Avatar
I would run a supplemental heater until I got it figured out.
We use ours often. When temps are above 32 it almost a staple. However the moisture build up requires a dehumidifier. Good luck!! Stay camping my friend...
donanddona is offline   Reply With Quote
Old 05-07-2015, 08:33 AM   #11
vinmaker's Avatar
I notice some Motorhomes have dual A/C units on the roof - presumably for hot climates. Would it be possible to install dual heaters since you live in a colder environment?
It might just be asking too much of a single heater.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 10000#
Old 05-07-2015, 09:44 AM   #12
We havehad other rvs and motorhomes.. Neverever had a problem with the heater in those... We are headed into a very hot summer in the nwxt few weeks. So will put it on our list of things to fix
Old 05-07-2015, 12:11 PM   #13
Canadians Freezing
Hey, never mind the Canucks, how about the Yankees in N. Dakota, Minnesota, Michigan etc. The ice storms don't stop at the border. LOL
flugelboneman is offline   Reply With Quote
Old 05-07-2015, 12:45 PM   #14
We use a small electric heater to suplement the furnace or when we don't want to run on propane constantly and it helps a lot. Our furnace on our Sureveyor is fine though at any temporature even in early April in the North Okanagan of BC. No vent in the bathroom does make you want to keep the door open at times though.
Dan
2020 Chevy Silverado RST
2014 Surveyor Select SV 264
2020 - 4 Nights Camping - Covid and Surgery does that.
Beluga is offline   Reply With Quote
Old 05-08-2015, 07:39 AM   #15
They and their money are welcome! We Floridians pay sales tax and have no income tax. [emoji6]
Sent from my phone using Tapatalk in Gainesville, FL.
TV: 2021 Ford F-150 4WD XLT Crew w/ 3.5L EB & HDPP, payload: 2,416#.
Camping nights: 2021, 52; 2022, 99; 2023, 88; 2024, TBD (Est: 80+)
chriscowles is offline   Reply With Quote
