Old 09-10-2016, 08:52 PM   #11
wayne and sherry's Avatar
Name:	ImageUploadedByForest River Forums1473558228.251112.jpg
That's about the best l can do for ya now.Click image for larger version
Name:	ImageUploadedByForest River Forums1473558364.035860.jpg
This is the mount l used, but in this pic the part of the mount that's on the right would be clocked 90 degrees so as to clamp on the pole of the ladder. Then just use one of the 4 screws of the mounting bracket to attach a good grounding wire that you'll run down and under your motor home finding a good place on the frame to attach the other end of that grounding wire.
wayne and sherry is offline   Reply With Quote
Old 09-10-2016, 08:57 PM   #12
Using a 4' fire fly antenna and a 50' hunk of coax you should see a 1.3 SWR.
Old 09-11-2016, 08:02 AM   #13
niedobry1's Avatar
Thanks for your help. The Snipe here.
niedobry1 is offline   Reply With Quote
Old 09-11-2016, 10:06 AM   #14
Right on. Let me know how your set up works out.
Old 09-11-2016, 10:27 AM   #15
rattleNsmoke's Avatar
I use a K30 mag mount on the roof of my pickup coupled to a Bearcat CB. The combo works good except 1.3-1.4 is the best I can do on the SWR's. It still makes the trip though.
1988 Harley Softail Custom "The Fireman"
rattleNsmoke is offline   Reply With Quote
Old 09-15-2016, 05:40 PM   #16
Cyber Phrenologist
Radio's Avatar
Take the truck out somewhere free of cars, power lines, any sort of obstruction. Like the middle of a football field. Measuring the SWR only when the trucks doors are closed, try adjusting/trimming the antenna again.
Although really 1.3 - 1.4 ain't bad.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 09-15-2016, 05:54 PM   #17
Flybob's Avatar
You can get small inexpensive manual antenna tuners for 11Mhz. Getting SWR close to 1:1 on CB's is important as many of them contain circuitry to fold back power if antenna match is not good.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 65W solar panels
Old 09-15-2016, 07:25 PM   #18
B and B's Avatar
I would be more concerned with 50 ft of coax. I would use some low loss like LMR 400 to make the 4 watts go far unless you are running a boot!
B and B
2017 Heartland Bighorn 3575 Elite
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
"Oh Canada,True North Strong and Free!"
Old 09-16-2016, 11:27 PM   #19
I didn't realize people still use CBs. 10 4
colourful64 is offline   Reply With Quote
Old 09-17-2016, 10:41 AM   #20
Oh heck yea!!! CQ CQ CQDX Whiskey Alpha Yankee November Echo 0210 QRT QSK QRM.
radio
