Was it easy to install? That is what i ordered. It should be here tomorrow. The only problem is they didnt have a kit for 2016 so i ordered the 2015 kit.
I put on the roadmaster as well. Took all of about 30 minutes and makes a huge difference.
2014.5 FR3 25DS for the family!
1989 Wrangler YJ for fun!
29er Mountain bikes for stress relief!
As many RV trips as possible for the lifestyle!
Very easy installation, nailed it on first try, no re-adjustment required. Just make sure your tires are turned as straight as possible. Up to you, but I would suggest getting an alignment when done. My "total toe in" was way off. Should not be different from 2015 to 2016, same chassis.
Just be aware that though you have a 2016 fr3 the F53 chassis might be a 2015 though they are probably identical. It is common for them to be different years.
Hey Philv check out the guide.
You need the RSSA stabilizer, the bracket could be one of the two listed. Mine took the RBK9. I would suggest you call Roadmaster with your VIN and they can confirm the bracket. Also do a price comparison on Amazon. I purchased from Amazon and saved quite a bit.
Before you spend any money on any chassis improvements, I would look at doing the CHF first. Don't let the name fool you, it may be cheap (free actually) but for the vast majority of people that do it, this significantly improves the handling of the F53.
waiter21 your right the CHF is free as long as you do it yourself which I did and it makes a huge difference in the handling of the coach. Unfortunately it will do nothing for you in the case of a front tire blowout. The steering stabilizer will return your steering wheel to center should that happen and allow you to make a safe stop keeping your loved ones safe. I had noticeable handling improvement after I installed it beyond the CHF after I installed it.
