Old 08-11-2015, 05:17 PM   #1
Chassis
What Chassis is under the FR3 30DS? I have a 2016 and want a steering stabilizer.
ostmd is offline   Reply With Quote
Old 08-11-2015, 05:57 PM   #2
leisurelarry's Avatar
F53 18,000 lb
leisurelarry is offline   Reply With Quote
Old 08-11-2015, 06:07 PM   #3
I installed a Roadmaster Reflex Steering Stabilizer on my 2015 30DS. The improvement in the handling was awesome. So much easier to drive.
Old 08-11-2015, 06:18 PM   #4
Was it easy to install? That is what i ordered. It should be here tomorrow. The only problem is they didnt have a kit for 2016 so i ordered the 2015 kit.
Old 08-11-2015, 06:27 PM   #5
I put on the roadmaster as well. Took all of about 30 minutes and makes a huge difference.
2014.5 FR3 25DS for the family!
1989 Wrangler YJ for fun!
29er Mountain bikes for stress relief!
As many RV trips as possible for the lifestyle!
Meathouse is offline   Reply With Quote
Old 08-11-2015, 06:31 PM   #6
Very easy installation, nailed it on first try, no re-adjustment required. Just make sure your tires are turned as straight as possible. Up to you, but I would suggest getting an alignment when done. My "total toe in" was way off. Should not be different from 2015 to 2016, same chassis.
Old 08-12-2015, 07:12 AM   #7
I have been trying to find out the number (size) for my 2014 FR3 28DS Chassis. ? Thanks.
philv is offline   Reply With Quote
Old 08-12-2015, 10:23 AM   #8
StephanFR3's Avatar
Just be aware that though you have a 2016 fr3 the F53 chassis might be a 2015 though they are probably identical. It is common for them to be different years.
StephanFR3 is offline   Reply With Quote
Old 08-12-2015, 10:54 AM   #9
Hey Philv check out the guide. Click image for larger version
Name:	ImageUploadedByForest River Forums1439393145.047870.jpg
You need the RSSA stabilizer, the bracket could be one of the two listed. Mine took the RBK9. I would suggest you call Roadmaster with your VIN and they can confirm the bracket. Also do a price comparison on Amazon. I purchased from Amazon and saved quite a bit.
Old 08-12-2015, 12:19 PM   #10
I called roadmaster and they said RBK9 was the right one for the 2015. That is the one I ordered. It came in today, I will try it Saturday.
Old 08-12-2015, 01:13 PM   #11
Thanks leisurelarry.
Old 08-12-2015, 02:31 PM   #12
waiter21's Avatar
Before you spend any money on any chassis improvements, I would look at doing the CHF first. Don't let the name fool you, it may be cheap (free actually) but for the vast majority of people that do it, this significantly improves the handling of the F53.
Cheap Handling Fix – and then some | 2001 Coachmen Mirada 300QB
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 08-12-2015, 03:45 PM   #13
waiter21 your right the CHF is free as long as you do it yourself which I did and it makes a huge difference in the handling of the coach. Unfortunately it will do nothing for you in the case of a front tire blowout. The steering stabilizer will return your steering wheel to center should that happen and allow you to make a safe stop keeping your loved ones safe. I had noticeable handling improvement after I installed it beyond the CHF after I installed it.
Old 08-12-2015, 03:46 PM   #14
Your very welcome philv!
