Old 08-01-2014, 05:04 PM   #1
adamrayburn's Avatar
Chassis Battery Drain
Something is draining the chassis battery and I have to jump it after just a few days. At first, the radio and backup camera monitor was hard wired to the chassis battery, and now is fixed - but still drains.
Dealer detects a .5 amp draw, but does not think of it as an issue. If it sits 3-5 days, the battery is completely dead. Battery tested good. Dealer suggested a battery disconnect switch on for the chassis - and said this is found on some other motorhomes. True or not? Suggestions?
Current
2014.5 Forest River FR3 30DS (First Motorhome)
Previous
2010 Coleman Evolution E3 (Popup TH)
2011 Keystone Cougar 325SRX (5th Wheel TH)
2008 K-Z MXT 266 (Bumper TH)
adamrayburn is offline   Reply With Quote
Old 08-01-2014, 05:53 PM   #2
Make sure the tv booster isnt being left on or hard wired.
Just a thought.
zippyzrx is offline   Reply With Quote
Old 08-03-2014, 09:36 AM   #3
I believe we have a battery disconnect switch at the bottom of the closet next to the stairs.
leogeo is offline   Reply With Quote
Old 08-03-2014, 12:07 PM   #4
HAPPY WHEN RV'ING
drivmsafe's Avatar
That disconnect switch by the stairs is for the home batteries, not the chassis.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 08-03-2014, 05:55 PM   #5
There is a roller switch that controls your instrument panel background lighting, that is probably switched all of the way on. This will open up a relay on the f53 chassis that if left open will drain your chassis battery. I would check this first.
FR3-SalesTrainer is offline   Reply With Quote
Old 08-03-2014, 06:56 PM   #6
camaraderie's Avatar
Try this...8 bucks on Amazon and a sure solution!
http://www.amazon.com/Post-Battery-M...connect+switch
How to Video:
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 08-03-2014, 09:06 PM   #7
Bobb36's Avatar
You need to check this instrument cluster dimmer switch it should not be all the way to the left and if that's not the problem you need to take it back to the dealer a .5 AMP draw is NOT acceptable.
2014 FR3 30DS
2014 JEEP WRANGLER WILLYS
Bobb36 is offline   Reply With Quote
battery, drain
