Old 04-01-2018, 08:29 AM   #1
Cheap handling fix
Is there a CHF for the rear
And what are the best tire covers for a
2018 30ds and do I really need them
frankie D is offline   Reply With Quote
Old 04-02-2018, 06:36 AM   #2
Carl17's Avatar
CHP
YES REAR AND FRONT
Carl & Bette
2018 Leprechaun
NEW YORK
Carl17 is offline   Reply With Quote
Old 04-02-2018, 08:09 AM   #3
Where can I find the info on the rear fix
Old 04-02-2018, 06:34 PM   #4
rk06382's Avatar
Read this thread: New 2018 FR3 28DS
I had a tire shop do mine. Made a big difference.
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
Old 04-02-2018, 09:11 PM   #5
HONDAMAN174's Avatar
Just did one on a friends jayco. Combined with sumo springs- huge difference!
Just glad to get away
Old 04-03-2018, 07:17 AM   #6
Carl17's Avatar
rear
Same as front , move sway bar to second hole close to rear end.
Carl & Bette
2018 Leprechaun
NEW YORK
Old 04-03-2018, 07:38 AM   #7
Thanks for the info going to check it out this weekend
Old 04-13-2018, 04:11 AM   #8
LytesOutFR3's Avatar
I just came back from AZ to see the Grand Canyon. Trucks, high winds through the desert and potholes everywhere. The CHF made a very noticeable difference. Going around turns at slow speeds arenít scary anymore. Much better handling
LytesOutFR3 is offline   Reply With Quote
Old 04-15-2018, 07:16 PM   #9
Capt6pak's Avatar
as other said its the same. move to the back holes. back is no as easy as the front. i spent a little extra time and unbolted the strut from the frame, the bushings have splines in them so i repositioned the spline and re bolted.made everything much easier to work with. used the floor jack to align hoes.
do both the front and back CHF and add either a safe-t- steer of roadster reflex to the steering link arm and you will be amazed. just drove for 5hr today with head and cross winds of 25. i was pushed around a bit but she always came right back to center.
2018 FR3 30DS
1997 and 2018 Wrangler
Capt6pak is offline   Reply With Quote
Old 04-15-2018, 07:23 PM   #10
I installed a Blue Ox Tru Trac tying the differential to the frame and this took 80% of the sway out. Before that, driving on an interstate with semis passing was a pants wetting experience.
anolefan4life is offline   Reply With Quote
