Old 07-29-2017, 09:54 AM   #1
FireSurf's Avatar
Check Fuel Cap
I had the check fuel cap light come on. I screwed it back on and light is still on. Anyway to clear this? Anyone have this problem?
2015 FR3 30DS
FireSurf is offline   Reply With Quote
Old 07-29-2017, 02:50 PM   #2
Try cleaning the rubber seal with a paper towel and also around the neck of the gas fill tube. May have a big of dirt or debris.
KY25DS is offline   Reply With Quote
Old 07-29-2017, 03:03 PM   #3
It also does not turn off immediately, it may take a few drive cycles.
TheGerman is offline   Reply With Quote
Old 07-29-2017, 03:31 PM   #4
StephanFR3's Avatar
ID:	146470 Yes with one of these.
StephanFR3 is offline   Reply With Quote
Old 07-29-2017, 04:15 PM   #5
M109Rrider's Avatar
https://www.amazon.com/dp/B005NLQAHS..._vQpFzbVYJQT0M
I have one similar to this and use the torque app on my phone
Jason and Billie
2018 F-250, 6.2L
2011 Prime Time Crusader 320RLT
M109Rrider is offline   Reply With Quote
Old 07-30-2017, 02:29 PM   #6
HAPPY WHEN RV'ING
drivmsafe's Avatar
You may also want to have your gas cap tested to be sure it's venting properly. Most shops or part store can do this for you.
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 07-30-2017, 02:43 PM   #7
StephanFR3's Avatar
If it is your cap. My past experience is if you buy a new one, the factory ones are alot better than the cheaper aftermarket ones. Buy it online through usually alot cheaper than the dealer, but you must do your research and know your part numbers.
check, fuel
