Old 03-19-2018, 08:59 AM   #1
Checking Tire Pressure
We just purchased a 2018 32ds and I am curious what everyone is using to check the tire pressure. Just getting to the valves seems like a pain. I知 thinking I just need to drop valve extenders on all the tires and call it a day.
fiveoh is offline   Reply With Quote
Old 03-19-2018, 09:01 AM   #2
marinerjoe's Avatar
The BEST thing you could do is install a TPMS system like the TST 507 Color system. It'll monitor the pressures AND temperatures, and if you have any questions, Mike Bensen from TST is a FREQUENT poster here and will be happy to answer any of your questions.
Joe
Current: 2018 Flagstaff MicroLite 21FBRS
Past: 2005 Flagstaff Classic 625D
TV: 2016 Ford F-150 3.5 EcoBoost
marinerjoe is offline   Reply With Quote
Old 03-19-2018, 04:00 PM   #3
Wasnt hearing good ownership experiences using external temperature/ pressure sensors. Too many reporting loss of sensors in any number of different conditions.
Prefer an OEM style air system monitoring.
Had excellent experience with a DILL TPMS, bought through Americas Tire.
A 10 sensor system was reasonably priced, and you can put it on your Americas Tire card with 6 months no interest.
Being inside the rim, sensor longevity is closer to OEM style ie your cars.
michael
repsolgamma is offline   Reply With Quote
Old 03-19-2018, 04:13 PM   #4
Gumpster808's Avatar
Absolutely zero issues or loss from our TST all last season. Always monitoring and alerting as it should have.
OEM is basically internal which you can buy from a number of aftermarket vendors and I believe TST has them as well.
Depending on overall length may need the repeater to ensure a good signal to the monitor.
Lynn & Dennis
Nights Camped 2017 - 35 / 2018 - 15
2014 3051S - First RV for us
2018 Hyundai Elantra Sport Toad
2015 Harley CVO (retirement bike )
2015 Challenger ( Wife's Toy)
Gumpster808 is offline   Reply With Quote
Old 03-19-2018, 04:51 PM   #5
I had TPMS on my last rig. I値l most likely put them on this one. For those that have the external systems I知 assuming you used valve extenders? I just can稚 see a way to get air into the tires without them due to their location.
Old 03-19-2018, 04:53 PM   #6
2014 DS25 has air valve extenders from factory.
2018?
Old 03-19-2018, 05:05 PM   #7
2018ds has extenders for the inside rears but that is it. Just getting to front and outside rear is extremely difficult though.
Old 03-19-2018, 05:08 PM   #8
Semi-truck air chuck is helpful, but not a necessity.
Any truck stop would sell one in a pinch.
Old 03-19-2018, 08:20 PM   #9
I put 90 degree valve extenders to the outside rears . I use a blue point digital tire pressure gauge . Works good for me .
Frameman is offline   Reply With Quote
Old 03-19-2018, 09:19 PM   #10
Perfect! Thanks for the info
check, pressure, tire
