Old 10-12-2016, 08:30 PM   #1
"Chf"
Fr3 32ds
Any recommendations on where to get "chf" done in South florida.
Nsopti is offline   Reply With Quote
Old 10-12-2016, 09:04 PM   #2
HAPPY WHEN RV'ING
drivmsafe's Avatar
Originally Posted by Nsopti View Post
Fr3 32ds
If you're a DIY kinda guy, it's really easy to do. A repair shop would charge too much, IMHO
Smooth Roads, and, Drive 'em Safe
Curt & Isabel, & 9er (our Goldendoodle)
2014 Forest River FR3 30DS (Beasty)
2014 Honda CRV EX-L (toad)
drivmsafe is offline   Reply With Quote
Old 10-12-2016, 10:32 PM   #3
Can you provide me with exact part numbers for a 2016 fr3 32ds
Old 10-12-2016, 10:56 PM   #4
wayne and sherry's Avatar
Fr3 32ds
Make your way up to Lynchburg VA and I'll do the CHF for you for free. Takes about 30 min complete.
Sent from my iPhone using Forest River Forums yo
wayne and sherry is offline   Reply With Quote
Old 10-13-2016, 11:36 AM   #5
HAPPY WHEN RV'ING
drivmsafe's Avatar
There are no new parts required. You just need to remove the 2 bolts from the front sway bar front holes and re-position them to the back hole. They won't look like they line up properly but, with a little grunting, or a small jack, you'll be able to get them in.
On the rear sway bar you'll remove the bolts and swing the shackle around and reinsert the bolts.
There is another earlier post titled "cheap handling fix" that has some pictures.
Good luck!!
Old 10-13-2016, 08:57 PM   #6
Fr3 32ds
I'm in Ft Lauderdale. I'll do it for a Sixpack. Where you located?
DutchRv is offline   Reply With Quote
Old 10-14-2016, 02:14 PM   #7
Former Full Timer
Duckogram's Avatar
You can do it for free however I suggest you get the helwig adjustable links for the front so you don't have clunking and premature bushing failure. It's still cheap with the links. You can search my posts for pics and part numbers.
FYI, Your chassis is Ford. Model number is irrelevant when you are trying to find chassis parts.
The recipe for perpetual ignorance is:
Be satisfied with your opinions
and content with your knowledge.
Elbert Hubbard
Old 10-14-2016, 02:41 PM   #8
lickem66's Avatar
I got the Helwig adjustable links but when I went to remove the top bolt that is in the frame (not the bolt that attaches to the swaybar) from the OE links on the passenger side, before the bolt backed all the way out, it hit what looks like the AC compressor. i could not remove the bolt. I hate to think I have to remove the compressor just to remove/replace that bolt to mount the Helwig link on that side.
2016 FR3 28DS
Past 2012 Forest River Rockwood 2104.
2016 Nights Camped = 34, 2015 = 21, 2014 = 22, 2013 = 24
lickem66 is online now   Reply With Quote
Old 10-14-2016, 02:49 PM   #9
Cut the bolt off and use one a little shorter for the reinstall.
Old 10-14-2016, 07:26 PM   #10
Yea, with a good quality hack saw blade and a little time just cut the bolt off, then replace with a new grade 8 and nylon locking nut.
