You'll find its the first stop for many to improve the ride quality. It stiffens up the chassis to prevent side to side roll. And it doesn't cost anything except 30 mins of your time hence the name. After the CHF, some may go on to add other suspension mods. Also, you'll probably find out the rear sway bar saddle will be loose on one or both sides. Its a known issue that typically comes loose over time. Like ours only had 5k miles on it and it already lost a bolt on the RH side and bent the saddle clamp. No ill effects IMO when doing the CHF, just positive experiences.
Mike
2015 FR3 30DS
