Old 09-20-2017, 10:26 AM   #1
City Water Fill Inlet Leak
After a couple nights at a state park I disconnected my hose from the city water fill on my 30DS. I replaced the cap on the inlet and came back a few minutes later and noticed water was leaking from the inlet soaking my storage area. I wiped it up and it still kept dripping and did so all the way home. Thoughts
George (Retired US Air Force)
Beverly (Retired Travel Agent)
2018 FR3 30DS
fritzg2 is offline   Reply With Quote
Old 09-20-2017, 10:32 AM   #2
Remove the small screen from the city water inlet connection and see if the check valve (plastic button) need reseated.
Days Camped: '16=46 '17=30 '18=51 '19=42
Old 09-20-2017, 10:59 AM   #3
When you suggest reseat will the button be in or out..Not sure I follow what is correct thanks
2018 FR3 30DS
Old 09-20-2017, 11:55 AM   #4
Not really in or out... just seated.
It is spring loaded.
Here's a video that might help you understand...
Old 09-26-2017, 07:26 AM   #5
wnelsonfl's Avatar
Water procedure
Do the following
Shut off city water
run water until stops
turn on water pump ( some water still in water tank)
run water for 30 sec.
turn off water
once pump stops turn off pump leave off ( do not use with city water)
turn on city water
This should re-seat /clean the check valve in the water pump.
wnelsonfl is offline   Reply With Quote
Old 09-26-2017, 01:18 PM   #6
If you take the screen out, just press the center to re-seat that valve. If your water pump is on or the plumbing has any pressure, stand back as you'll be sprayed with water.
Mike
2015 FR3 30DS
KansasFR3 is offline   Reply With Quote
city water, leak, water
