Old 05-28-2017, 11:30 AM   #1
City Water leaking into holding tank
Hey guys, I have a 2016 FR3. When i'm hooked up to city water occasionally for some reason it by passes and fills up my holding tank. It's a slow fill as when we get hooked up, the next morning there is water coming out of the overflow hose. I'm guessing there is a valve that isn't closing for the pump. When i took it to the dealer to have it checked they couldn't get it to replicate the problem. This has happened on a few occasions. Has anyone else experienced this and if so how did you fix it.
Jimmy
jimmy3rd is offline   Reply With Quote
Old 05-28-2017, 02:54 PM   #2
leisurelarry's Avatar
Jimmy
leisurelarry is offline   Reply With Quote
Old 05-28-2017, 08:54 PM   #3
2015 FR3
JEGNCJG's Avatar
We just had the same problem last weekend. I'm assuming there must be a check valve somewhere that is malfunctioning. Haven't had time to check it out yet.
JEGNCJG is offline   Reply With Quote
Old 05-30-2017, 06:13 PM   #4
We had the same problem. We now use a flow restrictor and and haven't had that problem since.
2 Happy Campers Kathy & Jay
2happycampers2 is offline   Reply With Quote
city water, leak, tank, water, water leak
