Old 08-01-2019, 07:34 PM   #1
Question Cleaning Air Conditioner
I need to clean the air conditioner from the inside of the coach, can you tell me how? Does the plastic cover with the vents come off? How?
2015 Fr3
rdmeese is offline   Reply With Quote
Old 08-03-2019, 07:38 AM   #2
KsWhoDat's Avatar
There are two tabs on the grill that you use to take the ac cover off (inside the coach), then you'll have access to the filter, which you should clean. Other than looking for any dirt or dust, cleaning the filter is the only inside task you need to do. Here's a quote from the dometic manual:
Air Filter - Periodic (a minimum of every 2 weeks of operation) remove the
return air filter located behind the return air grill and wash the filter with soap
and warm water. Let dry and then reinstall. NEVER run the air conditioner
without the air filter in place. This may plug the unit evaporator coil with dirt
and substantially degrade the performance of the unit over time
Jim & Cyndi
2014 FR3 30DS
2005 Dodge Dakota 4WD
KsWhoDat is offline   Reply With Quote
air conditioner, cleaning
