Probably not that simple, you need someone to check AC pressures, any Ford dealer can do that in 5 min. However, you first need to see if the AC compressor is running when you turn the AC on. Has it worked ok in the past? Mine had a bad thermostatic switch that prevented power to the compressor. Mine still blowing warm air (see thread below) 8-(
