Old 06-18-2019, 05:40 AM   #1
Coach audio
Hi all I hope this is a dumb question with a quick answer. We don't use the coach stereo system much I think I can count 2or3 time (2015) other than the outside tv. This year I push the power button and nothing happened. I am not very techy but come on!
RUTROAD is offline   Reply With Quote
Old 06-18-2019, 10:48 AM   #2
Head Rambler
Did you check the fuses?
Do the other 12 volt items in the RV work?
Gotta go campin!
Old 06-18-2019, 03:12 PM   #3
bikendan's Avatar
It would help if you posted year, make and model of RV since you don't have it listed in your profile.
Equalizer WDH
Old 06-19-2019, 09:16 AM   #4
007matman's Avatar
Is there a remote? Did you try that?
I know it's a silly question but my RV (it's an older model) audio system really only works well with the remote. When you touch the buttons all sorts of wonky things happen.
You'd think they would work that kind of thing out eventually.
007matman is online now   Reply With Quote
Old 06-20-2019, 08:29 AM   #5
Sorry I thought I did it's a 2015 FR3 30DS. It worked last year. But this year I have been trying everything I can think of and I did check fuses and remote
Old 06-20-2019, 10:57 AM   #6
Head Rambler
Did you check to see if you were getting power at the head unit?
Gotta go campin!
Old 06-21-2019, 05:49 AM   #7
Yes. Nothing I am hoping it's something dumb that I'm not doing. Frustrated
Old 06-21-2019, 10:31 AM   #8
lickem66's Avatar
Have you tried to just turn up the volume? or checked if it is on mute?
That's all I have other than slap your hand on the side of it a few times like we have to do on our computers now and then, right?
2016 FR3 28DS
Past 2012 Forest River Rockwood 2104.
lickem66 is offline   Reply With Quote
Old 06-21-2019, 06:36 PM   #9
TLAK's Avatar
The fuse for the head unit is the same one that the window shade is on, so if your shade works you don't have a fuse problem. On mine the yellow wire (12V power in) on the wiring harness pulled out. When I pushed it back in it worked intermittently but eventually I had to replace the harness. Only 16 wires to solder.
2015 FR3 30DS
Towing 2016 Chevy Sonic LT
TLAK is offline   Reply With Quote
Old 06-29-2019, 11:27 AM   #10
In addition to the power button on the unit itself, there is a rocker switch labeled "Radio" at the bottom of the center console.
2016 FR3 30DS
Thousand Oaks, CA
RV Trip Photos
vacationlovers is offline   Reply With Quote
