Coach Batteries
My last RV spoiled me. It had maintenance free batteries...
While prepping for departing for Colorado on the 17th, I turned on the battery switch so I could check the propane gas level. Humm... the battery light was showing "E". I quickly attempted to start the genny, the starter was dragging. 2nd attempt, it started!
I let it run for about an hour and shut it off. About an hour later, I checked the battery again. It was back on "E".
Then it dawned on me. Check the damn batteries. Yep, there is no visible liquid in there.
I go to the store and pick up distilled water and, believe it or not, a snot sucker like you use to clean small children's noses. (all the while kicking myself in the ass for not checking the batteries on a regular basis)
The snot sucker is perfect for putting the water in the battery cells.
I was able to restart the genny and let the batteries charge for a few hours last night. This morning I checked the batteries and they are at 2/3. I will be charging them today, and checking them again tomorrow morning. With my fingers crossed.....
Lesson learned...
If you don't have maintenance free batteries, CHECK THEM SUCKERS!
OldGunny
2016 FR3 30ds
