My FR3 is on a 2014 F53 chassis. The center position of the selector knob is off (indicator straight up). If the selector is not in the off position the mixing function will bring in some outside air, with the engine off it would feel cold. I think the engine needs to be running to successfully reset the damper position.
2015 fr3 30DS, added 2nd A/C-Heat Pump, both A/C have EasyStart, Auto Transfer Switch, CHF with Hellwig Links, Progressive Power Management, TPMS, Blue Ox True-Center, Koni Shocks, HID Headlamps, LED Foglamps, Pioneer Stereo, Keyless entry, Auxiliary Cooling Fans for A/C Condenser, dashcam front-rear, Yokohama Tires, air ride seats, onboard air compressor, 3000 watt hybrid Victron inverter Venus Generator Control, centramatic wheel balancers
