Old 06-28-2017, 12:37 PM   #1
Coleman Roadtrip Gril
Has anyone connected a Coleman Road trip grill to their FR3 propane tank? I have read multiple sources and watch several videos saying it is possible and my husband still is having problems. If you have done it can you please give us simple step by step directions on how you did it? Thanks in advance!
Aluminum Falcon is offline   Reply With Quote
Old 06-28-2017, 12:42 PM   #2
Iwannacamp's Avatar
They make a conversion kit to eliminate the regulator and run from the pre-regulated RV tanks. You can make your own with the correct fittings. Here is the kit(first one I found I am sure there is a cheaper source.
Coleman® Roadtrip® RV Quick-Connect Conversion Kit - propanegear
2017 Puma 297RLSS
Old 06-28-2017, 01:06 PM   #3
D W
D W's Avatar
If you want to connect it to your RV low pressure QD connector with a Camco hose (PN 57282), here is the most economic way. However, if you chose to use this method use the "YELLOW" Teflon gas tape, not the white or pipe dope. The latter are not compatible with propane's chemical composition.
'04 K3500 Silverado LS with LS3 Connect & Cruise- with Intimidator SSI PKG- Reprogrammed 4L80E
2016 Salem 27RKSS
D W is offline   Reply With Quote
Old 08-23-2017, 08:21 PM   #4
Did you figure it out? I did exactly that, and installed a T by the tank, and had my local gas guys make me a 15' hose, with quickconnects. I have pictures....
DutchRv is offline   Reply With Quote
Old 08-23-2017, 08:26 PM   #5
Found the threat with pics:
bbq off house tank
