Old 09-23-2017, 02:44 PM   #1
Converter
Last night the check light came on on our Dometic Refrigerator. We took out the manual and followed the directions. Light would not go off and we could hear it trying to ignite. Then the lights started to dim. Checked the shore power to make sure it was tight. Good there. Then the furnace would not come on. Checked the fuses and GFI- both good. Now starting to get worried.
Went outside to check the Power Converter. BINGO!!! Somehow it got unplugged - probably when we were getting our lawn chairs out we hit it. Next time we will check that first!! We learn something new every time we take a trip and that is a good thing. Hope this helps others. Have a GREAT day - we are now that every thing is working except our big slider, (which I posted a couple of days ago.)
Joni Tonkovich is offline   Reply With Quote
Old 09-23-2017, 02:48 PM   #2
You don't say year, manufacturer, model you have. UPDATE: I see you have an FR3; but year and model might help others.
I thought most (all) converters were hard-wired, not plug-ins. Surprised your is a plug-in. Especially in a location where you could hit it with something.
2011 Traverse LT, 3.6L, FWD
Old 09-23-2017, 03:18 PM   #3
from Cali
RV Pilot's Avatar
I think most if not all the FR3's are like that (I haven't seen the newest ones). It's a common situation on this section of the form.
______________________
2015 FR3 30DS
2014 Jeep Rubicon X
Central Coast of California
RV Pilot is offline   Reply With Quote
Old 09-23-2017, 03:31 PM   #4
My surge guard shut down power and then went to the 128 second countdown and power was back up. Something tripped it. Better safe than sorry.
OKI Marine is offline   Reply With Quote
Old 09-25-2017, 02:38 PM   #5
jjtonks's Avatar
Converter
Our Motor home is a 2015 FR3 - 30 foot. The converter is not hard wired.
jjtonks is offline   Reply With Quote
Old 09-25-2017, 02:40 PM   #6
Who Dares, Wins
doc73's Avatar
Sunseekers is plugged in as well.
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 09-25-2017, 03:14 PM   #7
Fulltime family RVer
I'd bet most converters are plugged in and you just don't realize it. My converter is plugged in behind my distribution panel. I've replaced it twice now (one failure and one upgrade) and really appreciate that it's plugged in.
I am surprised it's somewhere that it could be hit with something, though.
Old 09-25-2017, 09:52 PM   #8
Well, I'm used to the ones that are installed under the breaker/fuse panel like this one, as it's basically wired directly to one of the breakers:
Here's another one:
It would appear that if your converter is located somewhere away from your breakers, it will be a plug-in type, like this one:
Old 09-26-2017, 02:22 AM   #9
Well, I'm used to the ones that are installed under the breaker/fuse panel like this one, as it's basically wired directly to one of the breakers...
Interesting. I guess I take back what I said. I thought more would be plugged in with the 15-amp plug like they showed for the PD converter that was being installed in the first video.
Thanks for the video links.
converter
