Old 10-27-2015, 02:26 PM   #1
vfp
Converting or replacing gas hot water heater with gas/electric
Our 2013 FR-3 came equipped with a gas Suburban hot water heater. (The newer units have a gas/electric heater). How difficult is it to either modify our heater so that it will operate on electricity/or gas or replace it with one that will? Any suggestions will be appreciated.
vfp is offline   Reply With Quote
Old 10-27-2015, 02:44 PM   #2
Bluepill's Avatar
There are electric conversion elements available for many models. Use Google for source links.
2008 Itasca Meridian 37H
Old 10-27-2015, 03:57 PM   #3
TURBS's Avatar
Hott rod makes a kit.
Old 10-27-2015, 03:58 PM   #4
TURBS's Avatar
http://dg-usa.com/hott-rod/
Old 10-27-2015, 04:06 PM   #5
Consider the amperage available at your campsite !
wanderingbob is online now   Reply With Quote
Old 10-27-2015, 04:16 PM   #6
TURBS's Avatar
Fr3 is 50 amp ? No ?
Even if it is 30 amp I had no issues for years on 30 amp with electric water heater.
Old 10-27-2015, 04:31 PM   #7
fonzie's Avatar
What is model number of your water heater?
Fonzie
Old 10-27-2015, 07:24 PM   #8
Former Full Timer
Duckogram's Avatar
What Does This Switch Do?
My coach is 30A. Been using it for almost 2 years without a problem.
Edit: Don't let the name of the link fool you, it's about the water heater upgrade.
🦆 2018 GTS 2800QSF 🦆 The Adventure Continues
Pursuit 27KB - RIP - Killed by Irma
Cedar Creek 36CKTS - Retired in Titusville
Designer Legacy 3590RLTS - At the Lake
Bullet 215RBS - Went to a good home in KS
Duckogram is online now   Reply With Quote
Old 10-28-2015, 09:43 AM   #9
vfp
Converting hot water heater.
Originally Posted by TURBS View Post
Useful information. Thanks! Our FR-3 has 30 amp power. I will look into the "Hot Rod" universal kit.
Old 10-28-2015, 09:07 PM   #10
Dahagen
I have done 3 hot rod upgrades on my 3 motorhomes. Not hard to do, but make sure you connect the power through a plug-in or switch so you can shut it off if your water tank is empty and you are plugged into power.
dahagen is offline   Reply With Quote
electric, gas, heater, hot water, select, water, water heater
