Old 04-21-2017, 09:54 PM   #1
Converting to porcelain toilet
Apologies if this has been addressed - searched and can't find a conversation about it. We have a 2016 30DS. We would like to switch out the stock toilet for a porcelain. Should we purchase from Camping World or have dealer do it? Have any of you done this? If so, which model/brand? Thanks so much!
KevandSyl is offline   Reply With Quote
Old 04-21-2017, 11:15 PM   #2
SeaDog's Avatar
changing out a toilet is very easy DIY sort of job, I ordered my porcelain off the internet came in three days.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-22-2017, 05:19 AM   #3
Oaklevel's Avatar
What does your bracket look like they use several types. Our bracket is similar to this and looks to be 30-40 lb capacity.
ramco-eng.com
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Old 04-22-2017, 10:45 AM   #4
Curiouser and Curiouser
Rv Toilet replacement
Found this video on an earlier post. If the toilet seat replacement (with something other than plastic) doesn't do it for you, there are many choices for replacements (including porcelain) and as long as you get the right dimensions, this is a good DYI project.
Finch
2016 FR3 30DS
Finch is offline   Reply With Quote
Old 04-22-2017, 12:06 PM   #5
It is an easy swap. Consider getting the higher toilet so it is more comfortable.
Catalina 333RETS
Keystone Outback 23RS
Silverado 2500HD
Goldwing 1800GL
Wilco is offline   Reply With Quote
Old 04-22-2017, 12:15 PM   #6
I don't know what brand you have, but I just ordered one this morning (Dometic 310) from adventurerv.net. Check them out, they have great prices. Also, you can find video of the change out on youtube. Looks like a simple job.
FLTBIRD is offline   Reply With Quote
Old 04-22-2017, 01:32 PM   #7
satdog01's Avatar
Our tt came with the 310. Like the height and the easier to clean porcelain bowl. Only issue we had was with the Blue Streak dispenser and I installed the tee too close to pedal and chemical was not dispensing properly. After watching online Video, I saw my mistake. Was able to flip tubing and tee to near the top of bowl, works great now. Neverlessv the piping pulls out fron top of toliet to install without pulling the toliet in case your are interested.
Marriot II on Wheels 2017 Flagstaff Classic 832OKBS Diamond Pkg
2013 GMC Denali crew 6.6L 2500 HD DMAX w\Alison Trans
Pepper 🌶 Pomeranian rescue 289 nights as camping buddy
Days camped in FR, 2011-12 = 77, 13 = 59, 14 = 39
15 = 52, 16 = 77, 17 = 81, 18 = 44, 2019 = 45
Retired :
satdog01 is offline   Reply With Quote
Old 04-22-2017, 02:58 PM   #8
Easy to change toilets, unless you're like me with a bad back, bad knees, and poor eyesight. But even with those issues I did it, but I also promised myself I'd never do it again.
DrLewie
Flemington, NJ
Former: 2007 Cardinal 30W LE
Now:2018 Arctic Fox 27-5L
2008 Ford F-250 Long Bed Diesel
Total of 28 Months on the Road Since 2008
DrLewie is offline   Reply With Quote
Old 04-22-2017, 03:24 PM   #9
Wink
ramco-eng.com
Still trying to understand the relevance of this mount? ;-)
Jim & Pam
Ram 2500, Crew Cab
2014 Hemisphere 327res
JP Camper is offline   Reply With Quote
Old 04-22-2017, 03:40 PM   #10
When does a toilet equal a TV? The mount references above is for a TV. The toilet is mounted to the floor with a ring mount similar to the ones used in residential toilets. It uses a rubber gasket instead of a wax gasket and two bolts.
Now, I'll agree that there's a lot of effluent on TV, but the TV bracket won't work on a toilet.
DrLewie
Flemington, NJ
