Old 06-14-2014, 08:30 PM   #21
has anyone drilled & installed these marine cup in the top of the dash??
I've thought about drilling the hole, running the drill in reverse, so as not to crack the dash
svwc is offline   Reply With Quote
Old 06-14-2014, 11:02 PM   #22
Originally Posted by JerseyGuy View Post
I got one as well. I will screw it under the co-pilot window.
That is where i mou ted it for DW. just used 2 screws as it seems plenty stout. Even got it in brown and it matches pretty well. Will post up pick when i get back fro. LA. (work)
zippyzrx is offline   Reply With Quote
Old 06-23-2014, 11:51 PM   #23
Rfyler's Avatar
Name:	ImageUploadedByForest River Forums1403585338.492840.jpg
Hubby mounted this great cup holder for me. He bought it at a boat shop. When in use, you have your choice of a small or large top holding ring. (Water bottles or coffee cup) When you don't need it, the whole thing folds up flat against the wall.
Rfyler is offline   Reply With Quote
Old 06-24-2014, 08:29 PM   #24
sdusky's Avatar
Where did u pick up the cup holder?
sdusky is offline   Reply With Quote
Old 07-01-2014, 05:20 PM   #25
There are several styles like this. The one I got on Amazon is nicer with a spring tension holder. The one from CW has click type compression and does hole water bottles as well. The DW requires two, one for travel mug and one for water. When closed up they look the same.
Enconcapt is offline   Reply With Quote
Old 07-21-2014, 11:15 AM   #26
What is behind the wall when you drilled into it? Tried the other day to mount similar style under drivers window, above plastic armrest/switches and the drill bit, dull, didn't want to go much more than about a 1/16". Didn't want to force it so quit right there.
sherman12
2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 07-21-2014, 11:22 AM   #27
JerseyGuy's Avatar
Don't know. I used self tapping screws used for screwing together metal studs. Click image for larger version
Name:	ImageUploadedByForest River Forums1405959718.093939.jpg
2014 FR3 30DS In New Jersey
JerseyGuy is offline   Reply With Quote
Old 07-21-2014, 11:26 AM   #28
I used the small screws that came with the ones i bought. Also came with double sided sticky tape but ive found the screws hold better. Was hard as the material seemed to be sheet metal. But with enough speed and pressure they threaded into it no problem. Screws were very short that came with it.
Old 07-22-2014, 09:17 AM   #29
Good info guys, thanks! I tried to use short brass wood screws to no avail. Screws that came with the cup holders were to long I thought, maybe 3/4 to 1 inch. Think I'll re-try with screws that Jersey used.
sherman12
Old 07-22-2014, 02:06 PM   #30
PhotoMaster's Avatar
Not knowing the size of the ruler (inches, centimeters, etc.) I can only guess that the screws are about a half inch? (If each graduation is an 8th)
Greg, Barbara and Cody the wonder-pup.
2014 FR3 30DS
(and 2 200cc Scooters)
PhotoMaster is offline   Reply With Quote
