Old 10-24-2017, 10:08 PM   #1
Cutting into the sidewalls
Has anyone relocated their power cable yet? I am planning on wiring in a transfer switch and I would like to route the power cable through the sidewall or rear into a 50A power inlet. Iím just curious on cutting through the Azdel. As in does it splinter? I plan on using a Rotozip tool and am wondering if this is the best approach.
alexchuang is offline   Reply With Quote
Old 10-25-2017, 06:37 AM   #2
A32Deuce's Avatar
When I changed the fresh water inlet to one with a door and bigger, used the same tool to do it. Tap an outline and open up. Use Dicor and drill starter holes for any screws. Hope this helps. Just take your time, easy!
A32Deuce is offline   Reply With Quote
Old 10-25-2017, 07:24 AM   #3
Thanks!
Old 10-25-2017, 08:20 AM   #4
Head Rambler
A rotozip will work, but I much prefer a hole saw and/or an oscillating saw. Either of those will make a smoother and more controlled cut.
Gotta go campin!
