Old 10-02-2016, 10:46 PM   #1
Dash a/c fan not working.
2016 fr3 30ds dash a/c fan not working. Any help with locating the fuse.
wzaatar is offline   Reply With Quote
Old 10-03-2016, 12:04 AM   #2
Iggy's Avatar
If you have not lost power to anything else in the dash like radio or 12 volt plug etc I would suggest checking this fuse in the engine compartment.
It is behind the air filter.
It is Fuse #23 that powers your fan in AC and heating system.
ID:	122021   Click image for larger version
ID:	122022   Click image for larger version
2012 Georgetown XL - 378TS 49,900 miles
(2013 - 98 days) (2014 - 117 days) (2015 - 67 days) (2016 - 111 days) (2017 Est 115)
USAF Retired - MSgt
Old 10-04-2016, 12:54 AM   #3
Ours quit working too! And it cost 997 dollars to fix it and not covered by extended warranty. .. POS
colourful64 is offline   Reply With Quote
Old 10-04-2016, 07:15 AM   #4
Jim Wiemels's Avatar
We had the same problem with the the dash fan not working last December on our 2016 30DS four months after purchased. A serious issue since It controls windshield defrost as well as heat and a/c. After swapping the fan control on dash and fuses they found a bad diode located in the wiring..
Jim Wiemels is offline   Reply With Quote
Old 01-07-2017, 05:20 PM   #5
The dash fan works on my 2017 30'FR3, but it blows hot in summer and cold in winter (basically it only blows outside temp) selector doesn't change to defroster/ floor/etc. Any ideas ?
BILL49 is offline   Reply With Quote
Old 01-07-2017, 05:44 PM   #6
The problem with our 2016 FR3 30DS was a bad diode in a wire buried under the dash from the fuse box to the blower motor. They tried several things including swapping the dash heater controls with a new unit on the dealers lot before finding the issue. I would suggest you call the FR3 warranty contacts (shown below) at Forest River which have been very helpful in root causing several issues we have experienced. Our fan issue surfaced after only 2,500 miles over the Christmas Holidays when it was difficult getting service at the Dealer or Forest River because so many people were on vacation. Cel Lopez sent electrical diagrams through my contacting him to the dealer to help resolve the issue. Since then I have contacted both Cel and Chris to help solve other problems. Good luck !
Cel Lopez
Mid-West U.S./CAN. Class A
FR3/Georgetown Warranty Rep
clopez@forestriverinc.com
Direct: 574-206-7618
Fax: 574-206-2484
Chris Gorce
Forest River Inc.
cgorce@forestriverinc.com
Direct: 574-206-7635
Fax: 574-206-2484
Old 01-07-2017, 07:33 PM   #7
Jim..
Thanks for the info.. I think my problem is a little different than yours, as my fan blows, but only ambient air... the hot/cold control and directional knobs don't seem to do anything.. the fan speed control works OK .. thanks for the lead tho' I'll try to contact Cel.
Old 01-07-2017, 10:23 PM   #8
Just found out (by accident) that turning on my headlights resulted in my heater and distribution selector switches to work ! No kidding !! I turned off the headlights and the switches returned to previous mode. Turned lights on again and they worked ! SOMEBODY AT FOREST RIVER OBVIOUSLY MISWIRED SOMETHING !!! I hope this is not an indication of their quality control or lack of it !!
fan
