Old 04-29-2018, 05:03 PM   #1
Desperate immediate help needed
It's Sunday ... Dealerships are closed.. and we are full timers! We got locked out of our FR3 2015 30 D's. . The only window opened was that tiny bedroom window in the slide so managed to slide a stick in and get the emergency window open ...
Long story short. The lock is broke. We managed to get it off but how the heck do we figure out the right one to buy ? Is there a model numbrr
colourful64 is offline   Reply With Quote
Old 04-29-2018, 05:12 PM   #2
There should be some information either printed on or sruck on a tag.
donniedu is offline   Reply With Quote
Old 04-29-2018, 05:13 PM   #3
Nope.
Old 04-29-2018, 05:15 PM   #4
Ok found some numbers. Now what
Old 04-29-2018, 05:18 PM   #5
I donít know what kind of door lock you have but they make after market style door locks. I replace my factory lock with rv lock and it was the best thing I did. Itís a combo style lock.
In the future I would place a hidden key someplace in case this happens in the future.
cfiowa is offline   Reply With Quote
Old 04-29-2018, 05:19 PM   #6
Rvlock.com
Old 04-29-2018, 05:20 PM   #7
We have. A hidden key... I guess you missed the part about the door lock being broken. I'm also sitting here with an electric combination door lock that we purchased but it's much too small for the hole in the door.
Do the lock company's make a plate that goes over larger holes
Old 04-29-2018, 05:22 PM   #8
Try calling a locksmith with the numbers maybe they can match them.
2015 Forest River Wildwood DLX 402QBQ
Fuzzy164 is offline   Reply With Quote
Old 04-29-2018, 05:23 PM   #9
Sorry did not read into what you wrote. I do not have an answer for you. Good luck
Old 04-29-2018, 05:34 PM   #10
dbledan's Avatar
It appears to be a standard RV lock. You can find model numbers here.
http://www.rvlocksandmore.com/LocksKeys/Entrance-Locks
Is the deadbolt locked or just the handle?
If just the handle is locked you can take the 4 screws out and there should be a model number there. You could just order it already keyed with the same key if you want.
If your deadbolt it locked you may need to saw it off from the inside.
Best of luck!
dbledan is offline   Reply With Quote
