Old 08-24-2014, 04:43 AM   #1
Diagram for EntryStep problem... !!!!
To avoid problems with your entry steps and damage... consider installing 2 switches.......
I posted a diagram for the entry step problem.....
FR3 Slide Out Issue
pimhelmy is offline   Reply With Quote
Old 08-24-2014, 04:45 AM   #2
you break a core (cut it) and put a switch between.... and another one over the switch... so the magnet (it's a switch actually) is permanent CUT or MADE... this way you have a choice... 1) the step stays out permanently,,, regardless of the door being open or closed 2) the step stays in ... regardless the door is open or closed (so you can open the door and see if the step has a free path..... and not run into something... curb or so) 3) As it works now... step goes with door open etc... i will post a pic soon
Press the link on the above posting for pictures diagram FR3 Slide Out Issue
