Old 04-29-2014, 09:40 PM   #1
Unhappy Dish Tailgater
I just took delivery on a 2015 FR3 30DS. I have a Dish Tailgater system and attempted to hook it up. The only outside cable connection I have is labeled park cable in the left rear storage compartment. The system will not work when hooked up there. It does work if I hook up the cable directly from the dish to the receiver. Am I not seeing a satellite hook somewhere or do these motorhomes not come with a separate satellite hook-up. If so has anyone installed one on there own? Thanks in advance for any responses.
sunnyens is offline   Reply With Quote
Old 04-29-2014, 11:00 PM   #2
You have the same problem I have with the Coachmen Pursuit. They have no satellite prep package. I am hoping to run the line from my electrical compartment to the rear tv then HDMI cable out to the front TV.
Sent from my GT-P7510 using Forest River Forums mobile app
2014 Coachmen Pursuit 31BDP
2016 Ford C-Max Energi
1987 Chrysler LeBaron Convertible
FROG Member
FMCA Member #F438633 - Good Sam Life Member
Coachmens Owners Group Member
ResQfrog is offline   Reply With Quote
Old 04-30-2014, 07:37 AM   #3
bubbles's Avatar
It should work for you. What did you hook to the sat receiver antenna "IN" port when antenna was connected outside to park cable input? If you connected the "IN" port to a cable that is after a splitter it may not work. The "IN" port must be connected directly to the park cable input for your tv's which would be before any splitters and/or selector box. The only thing that would be different using the existing coax cable installation is you will not have HDTV but SDTV should work. For HDTV the HDMI ports on your sat receiver must be used and you probably don't have prerun HDMI cables in your unit. I utilize my park cable input for my tailgater antenna.
Old 04-30-2014, 05:09 PM   #4
tncruiser's Avatar
what i do is run a cable directly to my 211 receiver i drilled a 1/2 in hole under my front passenger window and finish it off with a round cable plate that has a rubber cap on it ,works well and appears stock
brianj
liven life in east TN and wherever my
2011georgetown280ve, and
2016 fordexplorer and hemi RAM
take us
tncruiser is offline   Reply With Quote
Old 05-01-2014, 10:07 AM   #5
Dish Tailgater update
I got the system to work using the park cable connection. As Bubbles advised me, the system will not work through a series of splitters. I removed the antenna booster from where it was mounted and then removed the "park cable" coax from the booster. I attached a length of coax to the cable and ran that to the satellite box. I was able to use the holes already there for the cable run to behind the tv. It worked fine. I have to order a converter to change my infra red remote to operate off a uhf signal and I can then place the satellite receiver in the cabinet behind the tv and everything will be neat and out of sight. Thanks to everyone for your replies.
Old 05-01-2014, 06:23 PM   #6
Motoring
grotto69's Avatar
Congrats on your new FR3, by the way!!!!!!!!
Safe Travels
grotto69 is offline   Reply With Quote
