Old 03-06-2018, 03:12 AM   #1
Do I have an inverter
I have a 2015 FR3 30 Ds and I'm going to install solar panels....
Let's put it this way.... I am going to struggle my way through it as I have no idea what I'm doing it... However, I'm gonna figure this out... Lol.
So, do I have an inverter ? And if so. Click image for larger version
ID:	164394will I need another one
colourful64 is offline   Reply With Quote
Old 03-06-2018, 03:33 AM   #2
Unless an inverter was added later the MH does not have one. The inverter would take power from the house batteries and "invert" it into 120V AC.
The solar panels charge the 12V house batteries, and need a charge controller for that. The two systems both connect to the batteries but have no other interaction.
TheGerman is offline   Reply With Quote
Old 03-06-2018, 03:43 AM   #3
Are you speaking of the FR3 ? Or of motorhomes ? Or of fifth wheels... I'm specifically asking for the FR3. As it already has AC and Dc....So I'm assuming it has an inverter.
Old 03-06-2018, 05:54 AM   #4
OYO
OYO's Avatar
Do you have AC/120 when your unit is not plugged in to AC from an outside source?
If yes, you have an inverter. If no, you do not have an inverter.
2016 Rockwood A213HW
2019 GMC Sierra Crew Cab Denali 6.2
Craig
OYO is offline   Reply With Quote
Old 03-06-2018, 06:01 AM   #5
cavie's Avatar
So, do I have an inverter ? And if so. Attachment 164394will I need another one
Not unless you have a residential fridge.
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 03-06-2018, 07:23 AM   #6
wmtire's Avatar
Maybe these links will help, as it seems you may not fully understand RV electrical systems.
Converter or Inverter (they are different)
Basic RV Electricity - RV Information (RV Maintenance)
RV Converters and Amp Draw - RV Information (RV Maintenance)
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 03-06-2018, 11:36 AM   #7
rk06382's Avatar
12DC
No.
FR3 12DC Wiring diagram.pdf: FR3 12DC Wiring diagram.pdf
I have purchased a Samlex EVO-2212 Watt Pure Sine Inverter/Charger to install in my battery bay. I also plan to double the batteries & add solar panels.
The EVO-2212 has an Three inputs: Shore power, Generator power and Solar power. It will output 2200 Watts.
I need to use a CPAP at night and my wife wants to be able to boondock.
Robert
2018 FR3 28DS
Samlex EVO-3012 Inverter/Charger| 400ah Battle Born LiFePO4 | Victron BMV-712 & MPPT 100/50 | 800W Renogy Solar | Fan-Tastic Fans | Blue Ox TruCenter | Dometic 320 | SnapPads |
Solar Power & Battle Born batteries thread
rk06382 is offline   Reply With Quote
Old 03-06-2018, 12:01 PM   #8
cavie's Avatar
Originally Posted by rk06382 View Post
No.
FR3 12DC Wiring diagram.pdf: Attachment 164409
check you cpap power supply. Some are 12 dc volt out. Mine is 24 volt dc.
Old 03-06-2018, 12:21 PM   #9
rk06382's Avatar
I have a 12v DC adapter for my CPAP but there is no 12v DC outlets in bedroom.
(also my wife wants to watch the TV)
Robert
2018 FR3 28DS
Old 03-06-2018, 01:48 PM   #10
INverter/solar panels
I hope you have Facebook. Search for Brian Boone, or Got Solar? and look over his pages for solar boondocking. Lots of hand drawn systems and trouble shooting as well as advice from people in the know, and people who ask the sort of questions you are asking. On the pages on the left side of the screen is a section called "files". There are parts lists for small, medium, and large systems.
You can also post the nomenclature off the data plate and someone will know if it is a converter charger or just what it is.
Simple suggestion, if you have a charge controller for the panels, simply hook them up to the batteries, and start charging right away. Worry about converting to 120 later, after you check out capacities of your system as it stands.
My system was installed by Brian Boone last year, and it works perfectly, charges the batteries, and can run 120 volts AC. Can run the TV, the ice maker and charge computer and cell phones, and still have enough 12 volt to run the C-pap machines. And still have hot batteries in the morning.
During the installation, I added two 12 volt plugs on the side of the bed frame, for the C-pap machines, bought an adapter for mine, and a small inverter for the Wife's.
hankpac is offline   Reply With Quote
inverter
