Old 04-25-2015, 08:51 PM   #11
Brother Les's Avatar
Originally Posted by Flybob View Post
You don't say what thermostat you have. If you have a Dometic Digital see link below for manual. You need to be on Auto setting to have fan shut off.
http://www.primetimerv.com/download/...structions.pdf
Thank-you, I have been looking for this manual.
Brother Les
Old 04-25-2015, 09:01 PM   #12
Originally Posted by FR3-25DSOwner View Post
Depends on where you are. Under normal conditions, it will shut off when the temperature in the RV is around the set point on the thermostat. If you are in Phoenix in July, it will likely never shut off if the thermostat is set to less than 75.
X2. That is exactly right. Because the outside temp is higher by a greater margin, and the fact that the insulation is minimal compared to a stick built home, your a/c can't catch up sufficiently to cycle off.
fan
