Old 04-24-2015, 01:18 PM   #1
Does a/c fan ever cycle off
I was wondering if the a/c fan is suppose to cycle off when in auto mode or does it allways run on low?
Chet
CARMAN is offline   Reply With Quote
Old 04-24-2015, 01:39 PM   #2
Chet
Mine cycles off when on auto
Papa GLS is offline   Reply With Quote
Old 04-24-2015, 03:23 PM   #3
Depends on where you are. Under normal conditions, it will shut off when the temperature in the RV is around the set point on the thermostat. If you are in Phoenix in July, it will likely never shut off if the thermostat is set to less than 75.
FR3-25DSOwner is offline   Reply With Quote
Old 04-24-2015, 03:53 PM   #4
Carl17's Avatar
Chet
You must check the fan run mode and make sure it is set to auto. because if it is not ac fan will never shut off.
Carl & Bette
2015 FR3
NEW YORK
Carl17 is offline   Reply With Quote
Old 04-24-2015, 03:55 PM   #5
tanner's Avatar
Our fan never cycles off, only the AC compressor
Rob, Denise and Niles
Avenger ATI 17QB
2011 Toyota Tacoma
Kayaks, Canoes and Surf Cart
tanner is offline   Reply With Quote
Old 04-25-2015, 09:10 AM   #6
We,l for hose with FR3 motorhomes you set the fan to Auto and it should go on/off. Hi or lo and it stays on full time.
zippyzrx is offline   Reply With Quote
Old 04-25-2015, 09:20 AM   #7
PhoneDude 8289's Avatar
Both units on our RV cycle off when the t stats reach set point.
Joe & Beverly
2014 Ram CTD, CC, SB
2014 8289WS lifted
PhoneDude 8289 is online now   Reply With Quote
Old 04-25-2015, 09:29 AM   #8
Flybob's Avatar
You don't say what thermostat you have. If you have a Dometic Digital see link below for manual. You need to be on Auto setting to have fan shut off.
http://www.primetimerv.com/download/...structions.pdf
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-25-2015, 11:59 AM   #9
Hi Flybob I have a Atwood Air Command with the heatpump unit this came on the 2015 Fr3 30d, the blower has 3 speeds and is very quiet. I had a Dometic on my travel trailer and the blower would shut off when in auto mode once the temp was met. This unit on auto mode will only drop down to low blower & cycle the compressor.
Chet
Old 04-25-2015, 08:37 PM   #10
Happy Camper
Fan Auto mode is the trick.
I found out after hearing the fan run all night that I had hit fan "lo" before setting the A/C temp desired on my 2015 Surveyor Cadet. Fan / Heat / Cool (A/C) are different functions on the control. Check all before turning the lights off for the night.
Johntgif is offline   Reply With Quote
fan
