Old 11-20-2014, 12:51 PM   #1
fdp
Does the DS30 have a outside propane connection for portable grills? I thought it doe
Does the DS30 have a out side propane connection for portable grills? I thought it does, however I don't see one.
fdp is offline   Reply With Quote
Old 11-20-2014, 02:11 PM   #2
TURBS's Avatar
Not according to this.
http://www.forestriverinc.com/ClassA...?page=features
TURBS.
Old 11-20-2014, 06:30 PM   #3
No it does not.
Also be aware, some propane grills have internal regulation. Mine does. So having a "camp side" tap wont work unless its plumbed in before the regulator.
cucamelsmd15 is offline   Reply With Quote
Old 11-20-2014, 08:06 PM   #4
fdp
Thank you
Old 12-03-2014, 09:22 AM   #5
what is easiest and cheapest way to plumb a connection for a grill into the existing propane lines? anyone done it?
Lfrazee is offline   Reply With Quote
Old 12-03-2014, 06:12 PM   #6
Technorick's Avatar
Camping stores carry a product called Sturgi flow or Extend a flow. That can be placed in line on the tank after the regulator that provides a t connection. Some have hoses included. However as the previous poster mentioned, be sure you understand the diff between hi and low pressure regulators and which your grille requires.
In the case of the FR3 if you were to do this, unless you want to cook on the street /drivers side you would have to either run the hose under the coach or around the front.
Another option is to have a qualified gas tech tap into the line that runs to the kitchen stove and heater. There is a diagram of the gas line on this forum in another thread called "FR3 diagrams".
But the question was "what's the easiest and cheapest way" way.
I buy 4 mini green cylinders from Walmart on sale. But I'm not full time camping.
Technorick is offline   Reply With Quote
propane
