Old 09-01-2018, 08:23 PM   #1
MaybzNDave's Avatar
Dometic fridge issue
Hi everyone
I have a 2016 30ds that is having some fridge power issue. It is a dometic mod # DM2652RBX. In the past I have had problems with it blowing the 3A AGX fuse in the motherboard but this time that was not the case.
The rig was plugged in, I started the fridge and the light came on. After a few minutes I went to check if it was getting cold and there was no power. I turned it off/on, tried it on gas only and then checked the fuse but it all seemed fine. Best troubleshooting I could do was find that it was not getting d/c power. None of the fuses on the motherboard or the fuse box by the batteries were blown so Iím flummoxed. Any body know if there are other fuses in between the battery and fridge, I cannot find a schematic. Or any other ideas?
Thanks for your help FR community
David
MaybzNDave is offline   Reply With Quote
Old 09-03-2018, 07:51 AM   #2
SeaDog's Avatar
I would go back and check all the 15 amp fuses and ensure the one for the frig is not blown. Even tho you were plugged in check your house batteries and make sure the converter is putting out 12V power.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 09-03-2018, 08:16 AM   #3
Did you remove the fuses and check them with a meter? Just looking at them is often not good enough.
2011 Traverse LT, 3.6L, FWD
Old 09-03-2018, 10:55 AM   #4
MaybzNDave's Avatar
Weíve already removed the fuses and checked them with a meter and thatís for sure not the problem. Thatís why weíre totally stumped.
Old 09-04-2018, 12:35 AM   #5
HortMi's Avatar
Mine has a breaker also, 28DS. Does it work on propane? Also check the outlet in the fridge compartment outside and make sure you have power to it and that it's plugged in. Use an extension cord also to check. As you know if the light in the fridge comes on you have power. My light also sticks in the off position so I have to wiggle the plastic arm to get it to come on sometime. You are also aware it takes about 8 hours of running time to cool the fridge ,right ?
HortMi is offline   Reply With Quote
Old 09-05-2018, 02:52 AM   #6
MaybzNDave's Avatar
Did not work on propane alone. I also have tiny fans hardwired in and they are not working and am well aware of how long it takes to get cold. I will try the extension cord though next time Iím at the rig, thanks for the suggestion.
dometic, fridge
